Home > My Defender > My 1994 300Tdi SW |
donmacn Member Since: 06 Nov 2017 Location: Nth Scotland Posts: 1851 |
Oh dear! Now you’ve done it….. but thanks for asking.
There actually should be many updates to this. I just haven’t got round to it, or found the ‘mojo’. I’ll see if I can make a start over the weekend. Donald 1994 Defender 300Tdi 110 SW - owned since 2002 - 230k miles and going strong (The 'rolling restoration' or tinkering thread: http://www.defender2.net/forum/topic58538.html ) 2000 Range Rover P38 4.0L V8 in the past.. RR classic - fitted with 200Tdi 1984 RR classic - V8 with ZF auto box 1993 Discovery 300Tdi not to mention the minis and the Type 2 VW camper... |
18th Jul 2024 7:47pm |
L110CDL Member Since: 31 Oct 2015 Location: Devon Posts: 10854 |
Many thanks if you can Donald Clayton.
20th Jul 2024 10:08am |
bbolstad Member Since: 13 Jan 2025 Location: Bergen Posts: 1 |
Nice work!
Where did you the ‘water channel’ for the 2nd row doors from? I really want a set of those! |
13th Jan 2025 5:34pm |
I must get around to updating this thread. Even if I say so myself I think there's some useful stuff to say!
On the water channel things, I'm sure these were 'proper' LR parts. I assume I saw them in one of the parts diagrams when I was sorting out which stuff I needed to buy. If my memory's correct, at the time I could get one side easily enough, but the other took a little while to order. On my old 2nd row doors, the part of the frame under the lock mechanism was one of the places where the corrosion was quite bad, so I thought that anything I could do to keep some of the water away had to be a good thing. Of course the new doors are galvanised, so less of an issue perhaps, but I still felt it was worth doing. I know the whole online parts diagram thing is a bit up in the air at the moment, but I went to the JLR classic parts one, dug down and found the right page. The parts are on the diagram - a "waterdam" - but showing as no longer available.... https://parts.jaguarlandroverclassic.com/p...and-rover/ Donald 1994 Defender 300Tdi 110 SW - owned since 2002 - 230k miles and going strong (The 'rolling restoration' or tinkering thread: http://www.defender2.net/forum/topic58538.html ) 2000 Range Rover P38 4.0L V8 in the past.. RR classic - fitted with 200Tdi 1984 RR classic - V8 with ZF auto box 1993 Discovery 300Tdi not to mention the minis and the Type 2 VW camper... |
14th Jan 2025 9:49am |
