Home > Off Topic > L405 |
Stacey007 Member Since: 25 Sep 2015 Location: Cheshire Posts: 3776 |
Hello
I would be surprised if they use the same dial if the option was not ticked, so it would only move right say for heat and show red dots and not move at all the other way. If it does move the other way for cooled seats, and turns blue, does the cars own A/C work? it may need a re-gas as I think it runs through this. Has he ever noticed the seats get cool? I have the option in mine but cannot remember if it was an additional option or with a Pack, so heated wheel, jets, etc... there is probably a VIN number look up you can see options somewhere |
7th Jan 2025 1:27pm |
walfy Member Since: 29 Aug 2007 Location: Frome Posts: 2672 |
Is the cooling system similar to the L663 system. So not AC related rather a heated/cooled plate thing that then blows hot or cold depending on the position of the switch.
Will check but I think his AC system works fine 110 D250 SE HT 110 USW SOLD RRE HSE Dynamic Gone, wife killed it VOLVO XC60 R Dynamic with some toys Polaris RZR 900XP SOLD |
7th Jan 2025 1:45pm |
J77 Member Since: 04 Nov 2019 Location: Fife Posts: 3418 |
On Defender the Dial moves both ways but only shows the blue lines if the option was ticked, I’m assuming RR is the same? Were they standard on RR? 24MY 90 D250 HSE, Tasman Blue
8th Jan 2025 9:46pm |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8123 |
Does it show blue dots when moved left? Cheers
James 110 2012 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
8th Jan 2025 10:42pm |
Yes it shows blue dots when turned as far as I'm aware.
Perhaps I need to get my head under their seat to see whats going on 110 D250 SE HT 110 USW SOLD RRE HSE Dynamic Gone, wife killed it VOLVO XC60 R Dynamic with some toys Polaris RZR 900XP SOLD |
10th Jan 2025 11:40am |
Just spoken to the owner of the casr, she says
I get blue dots but they don't turn on but when I twist the dial but the red dot does. So I'm assuming from this the blue dot illuminates but there is now cooling effect. From my quick research it seems the cooling elemnts are expensive and a pain to replace. 110 D250 SE HT 110 USW SOLD RRE HSE Dynamic Gone, wife killed it VOLVO XC60 R Dynamic with some toys Polaris RZR 900XP SOLD |
10th Jan 2025 11:47am |
Sounds like she has the option fitted it's just not working
Your correct. Pain to do and can be £££ for parts. Suggest some frost from the garden as cheap fix. Cheers James 110 2012 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
10th Jan 2025 1:35pm |
Sounds like a plan, she has decided that cooled seats isn't worth the effort of ££££s. 110 D250 SE HT
13th Jan 2025 12:54pm |
