Home > Maintenance & Modifications > Rear Tow / Recover, Worth It?
HardCharger
Hi All!
Just wondering if getting a NATO pintle or the Nakatanenga rear recovery / tow eye is a good idea.
I was thinking of them as just in case items but could be a catch hazard on steep inlines?
I'd appreciate any thoughts and advice on this as I'm in a position to get either or but worried it may affect my departure and approach angles?
Another thing I'm considering is just an NAS step and NATO pintle or will just direct to cross member? Or maybe the ORE NAS style bumper with a NATO pintle?
What do all y'all think? No Better Friend, No Worse Enemy
Post #1057212 13th Jan 2025 1:45am
34064
United Kingdom 2003 Defender 110 Td5 HT Alaska White
What a out a receiver hitch like those from Extreme 4x4 as they attach to the cross member and chassis rails then you can have your NATO hitch/50mm tow ball and recovery billet into it 110 Td5 Ex Utilities slowly converting into a pop top camper one day
Build thread:https://www.defender2.net/forum/post1024784.html#1024784
Post #1057224 13th Jan 2025 9:25am
Any NAS-style step will reduce your departure angle more than a NATO pintle or any BSAU24 (i.e., four-bolt) coupling fitted directly to the crossmember. If you do fit a NATO pintle of BSAU24 coupling to the crossmember of a TD5 or TDCi Defenber you must use an appropriate reinforcing plate between the coupling and crossmember.
Generally it isn't worth fitting a NATO pintle unless you want to be able to tow a trailer with a 76mm NATO lunette, since it really isn't very good ant anything else. You will also find that you walk into it frequently, and it hurts. A 5-tonne four-bolt BSAU24 pin/jaw coupling is more versatile (and less painful).
In my opinion the best and most versatile option is a receiver hitch, it really doesn't impact your departure angle, it can take any form of hitch, and you won't walk into it.
Post #1057233 13th Jan 2025 11:30am
