![]() | Home > Wheels & Tyres > Tyres sticking out beyond arches? |
Bps Member Since: 14 Feb 2016 Location: Lancashire Posts: 837 ![]() ![]() |
I’ve run various wheels tyres and offsets, which have protruded past the arches from a few mm to a good 2” and never had an issue but by far and away the best thing regardless of offset tyres etc to keep the car clean is fit a set of gwyn Lewis extended front mudflaps with out rigger shields. I’ve done it on every defender I’ve owned. On the rear of the 110 I currently have I also dirt defenders coupled with gwyns rear mudflap kit and mud shields which I have mounted the mudflaps slightly wider which keep the rear clean as well.
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20619 ![]() ![]() |
Is there much involved with fitting those? Chillin In The Backwoods🇬🇧🇺🇸
Factory wolfs are et20, however you can get aftermarket at et0. 235/85r16, 265/75r16 are a touch wider and 255/85r16 are taller and all suit the wolf wheel well and will sit in the arch. Lock stops can be adjusted easily, you don’t need to change the wheel to sort the clearance on the radius arm. Et0 aftermarket wolfs with adjusted lock stops will give a better turning circle, particularly on a 110
No pretty easy to do, they come with a decent set of instructions and didn’t take long, maybe an hour or so as I’ve done a few sets now, if you take your time a morning should do it. It’s quicker and easier with the front wheels off but do able if you just turn to full lock. Hardest part is fitting the mud shield up behind the inner wing and lining it up. |
Interesting, I might look into those sometime as keeping the muck and mud out has lots of positives.
LR Nuts Member Since: 10 Aug 2022 Location: UK Posts: 1221 ![]() ![]() |
![]() Click image to enlarge .... you know when you get it wrong ...... 1 the wheel and tyres 2 the side steps are on the wrong side ![]() |
