Home > Maintenance & Modifications > Which jacks for the 110
doruk1981
Switzerland 2002 Defender 110 Td5 SW Coniston Green
what car jacks and lifters are you using to lift your Defenders? I have a set for my Datsun and our mini but they are not high enough for the Defender Smile so for changing the axles, bushings and other bottom end jobs I'd need some advice on what the community preferences for home utilization ...
thanks in advance Td5 110 Station
Post #971971 22nd Nov 2022 10:01am
Dinnu
I do not have anything fancy or sophisticated.. just a basic trolley jack with a max height of about 400mm.
What you would need are a good set (or 2 sets, so 4) axle/chassis stands. I always lift by the axle to the desired height, and then lower until chassis rests on axle stands in case want to do something that I need weight off the axles. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #971973 22nd Nov 2022 10:11am
steveww
United Kingdom 2015 Defender 110 Puma 2.2 XS CSW Bronze Green
Remember to get a trolley jack with a suitable load rating, a 110 is heavy. Same for the axle stands.
Post #971999 22nd Nov 2022 12:49pm
Whilst this is true, also bear in mind that you won't be jacking the whole vehicle at once. A 1.5 tonne jack will be more than adequate and the deciding factor is usually its lift height rather than capacity, which often dictates a larger jack anyway. Darren
Post #972005 22nd Nov 2022 1:14pm
geobloke
Precisely... Thumbs Up
With a Defender, especially on taller tyres it is the max height of the jack that is important. Bear also in mind that a trolley jack used on anything other than flat concrete/tarmac is a PITA...
Post #972009 22nd Nov 2022 1:20pm
A 1.5 tonne jack will be approaching its limit if require to lift one end of a GVW 110 (3050kg) and certainly over its limit if lifting one end of an GVW HD suspension 110. My 110 DC weighs in at 2.7 tonnes in its normal running configuration, with 1.3 on the rear and 1.4 on the front axles.
It is useful to be able to lift the entire axle, and I do usually use a 1.5 tonne jack without problems. It is worth being aware that there is theoretically little margin. My old 1 ton (note, ton not tonne) jack will in fact lift either end (which raises some interesting questions about its relief valve) but does then very slowly let it down again.
Post #972014 22nd Nov 2022 2:15pm
Dinnu
All of my hydraulic jacks have (or had) the pressure relief valve on the ‘pumping’ side, so when trying to lift a heavier than rated load, the relief valve directs the pumping action back to the reservoir and the lifting ram simply does not extend further.
I still never ever trust a load on a jack. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #972022 22nd Nov 2022 3:40pm
Mossberg
United Kingdom 1993 Defender 90 300 Tdi HT Aintree Green
I have just replaced both the axle cases on my 90 (one at once). I lifted the truck on the axle so the wheels were clear (remember to loosen the wheel nuts) then support under the chassis, lower until you are sure of stability, remove wheels then lower axle as required (onto a trolley or similar).
Remember to remove parts as required. As I was swapping the axle case I could strip brakes, hubs, swivels, etc before lowering the case
I used a land rover bottle jack on one side and a standard 2 tonne trolley jack on the other. However, as another land rover jack came available, I purchased that and I can now use one at each end of the axle.
Just for information, I removed everything appart from the diff from the axle case then lowered it onto the trolley. You may need to use blocks to stop it tipping.
Post #972078 22nd Nov 2022 10:48pm
BaronDefenders
United Kingdom 2004 Defender 90 Td5 CSW Santorini Black
I’ve been using a fairly generic trolley jack for lifting both our 110s and 90.
I keep a Mercedes Sprinter jack in my 90 for emergencies. Charlie
1949 Series 1 80 (SOLD)
2002 Td5 90 (SOLD)
2008 Freelander 2 (SOLD)
1958 Series 2 88 Pastel Green (2019 LR Legends Best Restored)
1983 V8 110 Limestone (Previously owned by Tom Sheppard MBE)
2004 Td5 90 Santorini Black (Td5INSIDE Powered & Rebuilt by CSK)
2012 Puma 110 Zermatt Silver (Overlanding Build)
Instagram: @BaronDefenders
Post #972102 23rd Nov 2022 10:05am
Having had to use a Sprinter jack to change a flat tyre, it's worth being aware that it won't fit under the offside part of the axle, where the casing is thicker, if the tyre is completely flat. Solved by moving the vehicle so that it was on the board I carried for putting under the jack, but wasn't ideal when faffing around at the side of the road. Darren
Post #972107 23rd Nov 2022 10:36am
BaronDefenders
Worth bearing in mind. Thanks, LRA! Charlie
2002 Td5 90 (SOLD)
Post #972109 23rd Nov 2022 10:44am
Screbble
Mine’s a meagre 90 (that doesn’t move at the moment ☹️) but similar principles apply…
Also gave the convenient Sprinter jack inside the Defender with a suitable hardwood spacer/base Thumbs Up
Post #972175 23rd Nov 2022 7:59pm
Mcrevilll
United States 2009 Defender 110 2.5 TD X-Tech LE Nara Bronze
I had the same issue with my Land Rover and ended up going with a heavy-duty hydraulic floor jack. I also grabbed some axle stands for extra safety when doing the bigger jobs like axle swaps and bushings. A while ago, I needed a replacement part for the hydraulic system, and I found a great solution through Northern Hydraulic—they had exactly what I needed and were super helpful with recommendations. It made all the difference for those heavier lifts! If you’re doing a lot of work at home, something with a good lift range and sturdy build is key.
Post #1056913 10th Jan 2025 3:28pm
Ianh
Never leave the vehicle on an hydraulic jack for any job, use it to initially jack then support vehicle on stands and take pressure off jack.
Post #1056914 10th Jan 2025 3:40pm
