![]() | Home > Puma (Tdci) > Fuel leak from high pressure connection |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17711 ![]() ![]() ![]() |
The 2.4 WSM says that the lines must be discarded and not reused, however most people seem to reuse the without problems being common. If the sealing olives become damaged they will leak and the line must be replaced. The tightening sequence for both ends of the lines in the WSM is stage one 5 Nm (4 lbf ft) stage two 35 Nm (26 lbf ft).
It's very hard to say on the basis of your photo what is leaking and where from or even if it is for certainl a fuel leak. I would suggest that you clean the contaminated area thoroughly and see if you can see the where the stain reappears from. |
Johan_B Member Since: 20 Sep 2024 Location: Gothenburg Posts: 65 ![]() ![]() ![]() |
Thanks. Now I also found the line in the WSM stating that the old ones should be discarded, I thought I had read all the warnings but missed this one.
![]() I will clean the area and try to detect where it starts from. The pipes are not cheap so replacing on chance is not attractive. I am fairly sure it is fuel that is leaking. The front end of the truck has a strange smell to it after extended drives. Also the fuel consumption is a bit all over the place. We just came back from a 4500 km holiday trip, the first half of it was at 12+ l/100 km, going back it was just a bit over 10 l/100 km until after the last fill up, then back at 12 or more. Could be many factors of course and not related to this leak. |
