[For Sale] Defender swivel oil seal & pin kit
New never used parts needed to change the swivel pins & seals on a Defender 2008 onwards with ABS.
Only missing the drive member gaskets I think. All cost around £170 but not needed.
Collection from Lincolnshire or can post for cost.
£90.
Oil seal : FTC3401 x2
Swivel pin x2
FTC 3647 Gasket
Hub grease x2
FTC4785 seal x2
Hub nut x2
Pads set of 4
Kit swivel pin TAR100050 x2
Hub bearing outer RTC3426R x4
Spring kit x1
Brake pad fitting kit x1
Bearing taper 606666 x2
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot vote in polls in this forum
