Home > For Sale & Wanted > [Wanted] Salisbury disc axle for a 110
DR.Pepper Defender
United Kingdom 1995 Defender 90 Other CSW Rutland Red
Hello,
Looking for a disc Salisbury axle for my defender, I’m based in Yeovil in Somerset.
If anyone has one for sale that’s not a million miles away I would be very interested.
Thanks Dom Many defenders.....
Many series....
Many Range Rovers...
Got a problem....
Post #1056513 7th Jan 2025 3:35am
MarkBrown
Wales 1983 Defender 110 Other HT Auto Keswick Green
When I was building my 110 I bought a disc braked Salisbury axle for it, but unfortunately it was absolutely ruined ( I didn’t remove the cover to check - If I did I wouldn’t have bought it, but that’s hindsight ) so I used the original axle and converted to discs with mainly new parts and second hand front hubs. This has been great as the original axle was in good order with low mileage, clean oil and possibly little towing. All I needed to fit was a new drive flange and seal, along with a strip down and clean. I’ve also got two complete spare centre axles ( less brakes ) for it, should I need a replacement. 1983 110 automatic OM606
Post #1056523 7th Jan 2025 8:12am
DR.Pepper Defender
ok then, so I may be better buying the brackets and converting mine from discs... my axle is in decent condition with very little wear on the diff so that may be a better option.
thanks mark, giving me all the help today!
much appreciated. Many defenders.....
Many series....
Got a problem....
Post #1056571 7th Jan 2025 3:55pm
lfletch
United Kingdom 1993 Defender 110 BMW M57 3.0 Diesel CSW Portofino Red
Hi, Are you still looking for a Salisbury axle? I've recently taken one off my 200tdi 110. I did the disc brake conversion on it.
Post #1062548 10th Mar 2025 6:13pm
DR.Pepper Defender
Hello, yea still on the lookout for one, where abouts are you based?
Many series....
Got a problem....
Post #1063143 17th Mar 2025 3:06pm
lfletch
I'm based in south oxfordshire. I also have a galvanised salisbury axle casing that I was going to swap everything over to but never got around to it.
Post #1063152 17th Mar 2025 4:11pm
