Home > Off Topic > 1994 3 door Discovery buying advice please
CarMan
Randomly I have been given an opportunity to make an offer for what could be an interesting acquisition.
1994 'L' 64k miles one owner from new 3 door vehicle registered locally to me on 28 May 1994.
MOT expired Oct '22 and garaged for some years in London.
MOT history confirms circa 2k miles p/a consistently since 2007 until 2019 when the mileage tailed off somewhat due to owner's ill health.
No MOT fails and advisories only since 2020 for corroded coils, oil leak not excessive, thin rear pads and damaged valve stems!
Logistically it is a challenge, but seems potentially too good to just ignore so would like to pursue initially at least.
It's diesel, but unknown if auto or manual and I'm thinking possibly 200tdi?
I'm not keen to go look and find we are miles off on price and I would need to factor in tyres, recommissioning and transport and of course it could be rotten but looks tidy??
Any suggestions in particular as to value as I believe these may now be getting rare, would be very much appreciated. I have very limited pics so far.
Thumbs Up
 Rob
1993 200tdi 90 hard-top
1998 300tdi 90 soft-top
2016 2.2 XS 90 hard-top (sold)
Post #1056469 6th Jan 2025 5:19pm
Mdm
it should be a 200 tdi at the age.
rust it will have....
running and driving no issues its worth something to someone
start at scrap value for it and work upwards as recovery costs and recommissioning will soon add up
Post #1056473 6th Jan 2025 5:39pm
markb110
Hi Carman
?si=nkp9MGkjcQrNcXVc
Work your way through Sophie's 5 part series.
The main issues appeared to be the hidden rust behind the aluminium outer panels.
So difficult to tell from your picture, so i hope her documented experience helps you.
Worth noting, this young lady also rebuilt a Defender axle in the downstairs WC at her parents house!
Good luck
A friend of mine many years ago managed to get a Japanese import, as they don't use road salt it was mint.
Post #1056481 6th Jan 2025 7:21pm
CarMan
Thanks guys.
Those videos are a real eye opener and definitely not the sort of project I was wanting by a long way!
Time for a reality check maybe Wink
Post #1056485 6th Jan 2025 8:11pm
Devon-Rover
Going by the steering wheel and the mirrors it's 300tdi.
Yeah a 3 door has a less common number still on the road than the 5 door variants, still not enough to sway the value vastly, they are still disco's and they all corrode in the same places.
Mostly any of the inner steel frame. Battery box, inner wing, sill, boot floor, roof and rear arches to name the most typical rot spots.
A historical or noteworthy Reg will be minor plus on value.
IMO it's worth a nose as if it's been undercover then it won't of got damp and rotten like many, The likes of Project jay would be keen to see it saved as I said 3drs are not as plentiful as they once was.
given 6 ish years of limited use then you will be looking at brake work (calipers - pads etc) a good look at rubber items flexis tyres etc as you say as they do perish over the years.
Without more pictures It's hard to say if it's a brief resto to a full rebuild. no mentions of corrosion in the MOT suggests all is ok underneath maybe not clean but not bad.
as for value a rough one is about £1000 - £1500
Out of mot or little work to mot £1500 - £3000
I've seen road ones from £1750 to concourse ones at £10000+
The market is slowing a bit and thankfully the idiots have moved onto D2's and 3's to tear arse around the lanes on so good D1's hopefully can be found and saved.
Again condition is key but it sounds promising, From the picture and your description I would ball park it at £1750 - £2000 but it's not a guarantee and don't quote me as info is limited.
Thumbs Up Also can be found on Fb, Ytube, Insta & Twitter @4WDSouthwest
Post #1056499 6th Jan 2025 9:25pm
CarMan
D-R that's really helpful thanks very much Thumbs Up
Post #1056584 7th Jan 2025 5:21pm
CarMan
A couple of quick questions:
1. An guide as to scrap value would give me a good starting point
2. Ditto trailered collect/delivery cost per mile as a guide
Thanks.
Post #1056773 9th Jan 2025 12:56pm
