![]() | Home > For Sale & Wanted > [Wanted] Eberspacher/Webasto DefenderTd5 Fuel Stand pipe |
Screbble Member Since: 26 Apr 2015 Location: Lancashire Posts: 2172 ![]() ![]() ![]() |
Would this suffice?
https://www.4x4overlander.com/product/diesel-fuel-pick-up-pipe/ |
Dr Meat Member Since: 16 Apr 2022 Location: Northamptonshire Posts: 66 ![]() ![]() ![]() |
Thankyou, It would but unfortunately I’ve been waiting over a week for Brendan to respond to my emails.
Sorry to hear that.
Brendan and Barbara have always been a pleasure to do business with in my experience. Brendan is (was?) Leeds on here so maybe you could PM him? Hope you have better luck ![]() |
Landyash Member Since: 06 Feb 2011 Location: Nottinghamshire Posts: 287 ![]() ![]() ![]() |
There is a spare pipe point on top of the fuel pump in tank,
I used that on my old Td5 ![]() |
Hi landyash, did you have to remove the pump to insert a extra fuel line inside for the pick up?
I’ve seen you can get these type kits where you drop the line in from the top & was wondering if one of these would work, I’ve no experience with this but how different can aux pick ups be? ![]() Click image to enlarge |
There is a capped off connector to the right and down a bit of the electrical connector. It is even listed in the WSM as a fuel burning heater feed pipe... Number 1...
![]() Click image to enlarge Last edited by geobloke on 24th Jan 2023 5:32pm. Edited 1 time in total |
Hi geobloke
Thankyou for replying, is there a fuel line attached to the under side of the aux port (1 Fuel burning heater feed pipe connection) inside the tank or does the sender need to be removed for a line to be attached. Just for clarification my defender is for a 2.2 2015 110 utility. Which if I was using the scavenger I believe it’s the same part as the td5 as both have 60mm fuel neck. Sorry my wording in previous reply was probably misleading when I mentioned extra fuel line |
![]() ![]() ![]() Click image to enlarge |
I don't know, might help with the piles...
Ah well I confess I had to search for this answer... Apparently you need a 30cm long pipe to insert in to the fuel pump connector... https://forums.lr4x4.com/topic/49882-eberspacher-in-a-td5/ Also from this forum there is a Defender fuel burning manual that mentions an installation kit JEI100030 which I believe is LR's fuel pipe that fits in that blanked off connection... https://www.defender2.net/gallery/albums/u...to%207.pdf But it (JEI100030) might be obsolete, who knows... This is what the pipe looks like and it would be simple to DIY https://britcar.com/product.php/122997/549..._not_order Best I can do... ![]() |
Thank you so much that’s a big help, I’m going to wait for the heater to arrive and see what it comes supplied with first then make the decision whether to drop the tank or shell out another £100 for the neck scavenger from overland.
Yes I did have to drop the tank down and was a bit fiddly But was loads neater once fine 👍🏻 |
barbel jim Member Since: 12 Dec 2012 Location: Northants Posts: 1438 ![]() ![]() ![]() |
Snow has stopped play today….. don’t really fancy crawling around in it to fit the scavenger. I have the naka one which has absolutely no information. Cutting the neck to fit in line should be straightforward however my naka scavenger was supplied straight, presumably I’ll have to bend it ? Also don’t like the sharp point on the tank end. I read somewhere that someone bent it at 90degrees to keep of the tank, have others done this ?
Mine came exactly the same shape as the one pictured here, I removed around a 1cm section from the centre of the rubber filler neck tube.
![]() Click image to enlarge 2015 2.2 110 Utility Wagon. Daily & personal limousine to Bert the mastiff🐾😀 Instagram https://www.instagram.com/tonythe_defender/ |
