Home > Technical > ABS / TC lights not showing up by functional ABS system
Michael_the.roving.pups
United Kingdom 2011 Defender 110 Puma 2.4 CSW Aintree Green
Hi everyone,
I failed MOT a couple of weeks ago due to the ABS light not showing up during start.
I have a Defender 110 Station Wagon xs, ABS/TC been fitted from factory.
-A few brake tests have shown that the ABS does work.
-All fuses are ok.
-Cluster taken apart, no interference with LEDs, LEDs seem to work when tested with multimeter.
( lights up for a sec. )
- pulled the fuse to cause a fault, no ABS light shown
- disconnected battery to reset the ECU and ABS Modul
- no fault codes shown at all
Any suggestion what the issue could be?
Ps: bought the Defender in Nov. 2023 and can’t recall the ABS light ever showing up.
Cheers,
Michael.
Post #1056089 2nd Jan 2025 10:58am
Julie
France 2012 Defender 110 Puma 2.2 SW Keswick Green
So I'd first check if the handbrake light was still working.
2 / 3 amigos
And if the cables were functional
Post #1056104 2nd Jan 2025 1:38pm
Handbrake light is functional.
What cables do you speaking of?
Post #1056111 2nd Jan 2025 2:33pm
Julie
Connections to wabco ECU and mass
Post #1056114 2nd Jan 2025 2:48pm
