![]() | Home > Maintenance & Modifications > Windscreen Washer replacement - Puma 2011 |
Grenadier Member Since: 23 Jul 2014 Location: The foot of Mont Blanc... Posts: 5878 ![]() ![]() ![]() |
Salut,
Am I right in thinking that if I need to replace the front washer on a Puma, I need to remove the whole dash? Even the Optimill upgrade? Washer has just snapped off and obviously with melting snow, damp roads and mud, it’s a particularly in opportune moment. ![]() I've not been everywhere, but it's on my list..... 2011 Puma 110DC - Corris Grey |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17603 ![]() ![]() ![]() |
No, it can be done with just the centre panel remove, although it is a bit fiddly.
Phew. Thanks BW.
Ianh Member Since: 17 Sep 2018 Location: Essex Posts: 2138 ![]() ![]() |
Somewhere there is a how to on here with pics . IIRC as BW says , remove centre section of the dash. Remove radio. There is a metal (redundant) radio support bracket you remove and then you can get at the jet nut with a deep 13mm socket.
Here it is. See page 2, half way down, post by John Fair https://www.defender2.net/forum/topic50670...p;start=15 |
Thanks Ian.
