![]() | Home > In Car Electronics (L663) > Dead - subwoofer? |
Aulus Member Since: 24 Nov 2024 Location: Connecticut Posts: 9 ![]() ![]() |
Updated, I pulled out the boot fuse panel, Under F32, for speakers, to find there was no fuse in there. Popped one in a still nothing.
Moo Member Since: 01 Oct 2021 Location: UK Posts: 1432 ![]() ![]() |
Has it actually been fitted? Some builds post covid missed all sorts of bits off. Eiger Grey MY23 D250 SE with bits. Known as Noddy.
Yeah it's all in there subwoofer wiring. It was odd that there was no fuse though, woke up today. Battery was shot. The parking lights were doing this weird dance all night long. And had to jump start my car. I wonder if somebody pulled the fuse then because there's A short or something causing things to stay on in regards to the subwoofer
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20590 ![]() ![]() |
Possibly wiring in situ, but not connected up and fuse left out to isolate those circuit(s).
No guarantee it is that, but LR often would fit items, and wiring and put them in situ, but not connected up. Probably before options are customer selected. Keep the fuse out until fully investigated, itโs far safer for now until you can identify whatโs going on there. ![]() Big Brother is Watching. ๐ฌ๐ง๐ด๓ ง๓ ข๓ ฅ๓ ฎ๓ ง๓ ฟ๐ด๓ ง๓ ข๓ ท๓ ฌ๓ ณ๓ ฟ๐ด๓ ง๓ ข๓ ณ๓ ฃ๓ ด๓ ฟ๐ฎ๐ช๐บ๐ธโฝ๏ธ๐ข๏ธโ๏ธ๐งฐ๐ช |
Even if they were left situ, they still shouldn't have caused a drain like that no? Unless user error and I left parking lights on which I can't imagine I did last night.. battery was flat enough to cause the alarm to go off.
Is there a wire diagram,for the subwoofer, and connection where its suppose to mate to?, I'm pretty sure when I got the car to it was already enabled to have it. I don't remember after playing with the CCFs in Idd |
lightning Member Since: 23 Apr 2009 Location: High Peak, Derbyshire Posts: 2917 ![]() ![]() |
Have you looked under the passenger seat to see if the subwoofer is actually fitted? Slide the seat fully forward, remove the plastic inspection panel from the floor, and the subwoofer is off to one side.
Yup it's definitely there, the subwoofer and the harness, I also ripped off the rear side panel to see if the harness is attached to the amplifier; which it is.
If you guys look at your fuse panel in the boot, do you have a 5amp fuse at f32 it's brown. Aside from this I have to think it's a blown subwoofer.. My thoughts are either 1). Maybe some took out the fuse, for electrical gremlins 2). Maybe it didn't need the fuse from the factory. |
There is a permanent live draw there for that to happen, which was complete when the fuse was fitted, unless like you mentioned an accidental load was placed, which is less likely I think.
Itโs likely either the head unit was powered if that supplies the sub if itโs low wattage or an external amp, any amp or HU should only be on when the ignition is on. Possibly, the RMT12v turn on, on it is wired to permanent live when it shouldnโt be. And the RMT and the live supply is on the same circuit. That would cause the draw youโve experienced if the Amp or HU was permanently on. Is there any possibility someone else has been fiddling with it? If so, they might have wired it wrongly, and simply pulled th Eusebius out rather than sorting it out. I would imagine itโs a hardwire issue, rather than settings, you really need a wiring schematic in an ideal world. Play Stupid Games, Win Stupid Prizes. Big Brother is Watching. ๐ฌ๐ง๐ด๓ ง๓ ข๓ ฅ๓ ฎ๓ ง๓ ฟ๐ด๓ ง๓ ข๓ ท๓ ฌ๓ ณ๓ ฟ๐ด๓ ง๓ ข๓ ณ๓ ฃ๓ ด๓ ฟ๐ฎ๐ช๐บ๐ธโฝ๏ธ๐ข๏ธโ๏ธ๐งฐ๐ช |
It doesn't seem like anyone else has been in there.
My thought process is now then, if someone can confirm if they have a fuse under F32 - with a working sub. that if a similar occurrence happens overnight again, it's an electrical issue and I'll bring it to the dealer; because it's more then just a blown speaker, as you said. Perhaps something faulty from the factory.im sure they'll blame on the IDD CCFs I've done. |
If youโve got a warrantee, then for sure use it as itโs an issue thatโs not your fault.
CincyRovers1 Member Since: 30 Nov 2023 Location: Cincinnati, Ohio Posts: 102 ![]() ![]() |
Do you have the Meridian or the base audio? Meridian systems have adjustments for treble, bass and subwoofer. The base 6-speaker system doesn't have a subwoofer adjustment. The base system has the subwoofer, but it is only used for the fake engine noise and not for the sound system, and I don't think you can configure it to work with the sound system unless you do a full Meridian retrofit with the extra speakers and upgraded amplifier.
Even if you were able to get the subwoofer to work, the base audio system is still going to be garbage. The base 11-speaker Meridian is pretty good. Not excellent, but good. ๐๐๐๐ ๐๐๐๐๐ง๐๐๐ซ ๐๐๐ ๐ ๐๐๐๐ (Pangea Green over Acorn/Lunar) ๐๐๐๐ ๐๐จ๐ซ๐ฌ๐๐ก๐ ๐๐๐๐๐ง ๐ (Dolomite Silver over Black/Bordeaux Red) ๐๐๐๐ ๐๐ข๐ฌ๐๐จ๐ฏ๐๐ซ๐ฒ ๐๐๐ ๐๐ฎ๐ฑ๐ฎ๐ซ๐ฒ ๐๐ข๐ (Aintree Green over Vintage Tan/Ebony) - Gone ๐๐๐๐ ๐๐๐ ๐๐๐ ๐.๐ (Ipanema Sand over Almond/Arabica) - Gone |
