![]() | Home > Wheels & Tyres (L663) > Terrafirma 20” steel wheels |
jcthemaltesefalcon Member Since: 04 Jul 2024 Location: Nagano Posts: 12 ![]() ![]() |
I’m awaiting delivery of my D350 110 within the next 6weeks, and living in snow country I’ll be needing a second set of wheels with dedicated snow tyres.
I came across these proper steelies, about 5kg heavier each corner than equivalent alloys, but they’re solid, cheap and fit the Defender look: https://terrafirma4x4.com/terrafirma-20x8-...f1520.html Has anyone fitted or seen them fitted on an L663? Any issues I should be aware of before I bite the bullet? I’ll be running these at least 4/5months of the year. Thanks ![]() Click image to enlarge |
Thanks!
That would be my first choice but 18’s won’t fit on the D350 due to brake calipers. |
Mudlark Member Since: 14 Oct 2022 Location: North West Posts: 28 ![]() ![]() |
I have fitted these to my P400e but you may need spacers (as I did) if you have larger calipers.
I also fitted new Grabber tyres - same size but just scrape a touch on full lock on lower height setting. Presume a deeper tread pattern but I just lift the height if I need full lock when parking for instance. |
