Home > Technical > 2.4 Puma cold starting issues.
Page 2 of 2 <12
Ads90
United Kingdom 2007 Defender 90 Puma 2.4 CSW Keswick Green
I have the same issue as poster & Blackwolf - slow cranking until it stops and alarm chirps (just like a flat battery), but 2nd attempt it turns over fine and starts.
Recently changed the glow plugs which reduced smoke on cold startup, but made no difference to the weird slow initial turnover.
Post #1054881 16th Dec 2024 7:17pm
What you could do with is live rapid refresh rate voltage reading, I’m am sure that the voltage drop is significant. (Though the likelihood of viewing it and the problem / issue happening at the same time is slim).
That is, if it is voltage related of course).
The strange thing is though, how it is sporadic as to when it happens.
I had similar occur myself about a couple of weeks ago for no reason, it almost can make you feel like it won’t start at all for a split second. But then it does.
It almost seems like a dead short, but isn’t. Is this the same sort of thing that others have had?
Makes me wonder if it’s possibly some kind of ECU refresh, or repositioning of critical engine components, or checking of a components position. Sort of like say how a printer can occasionally program an alignment of the print head. No Guts, No Glory.
Post #1054888 16th Dec 2024 8:29pm
Ads90
^ Yes, exactly this. Always has my heart-in-mouth when we’re running late and sounds like it’s not going to start!
The other time it often does it is in filling stations - warm engine, just filled & paid, come to re-start & it dies, sometimes triggering the alarm! Turn key off, wait a few seconds, try again and starts no problem.
Post #1054893 16th Dec 2024 9:15pm
BrickBox
Have you checked around the injector area for any fuel leaks? Could possibly be the leak off lines cracked and causing a low fuel pressure on first starts. Get a torch in there and see if there is any fuel sitting in the rocker area.
Post #1054895 16th Dec 2024 9:24pm
The frustrating thing is that there are many diagnostic tests one could do, and it should be possible to diagnose the cause with certainty very quickly, if it wasn't so intermittent and so completely unrepeatable!
The Puma starting circuit is very simple after all.
(Edited for spelling)
Post #1054896 16th Dec 2024 9:27pm
*accidental double post.* No Guts, No Glory.
Post #1054903 16th Dec 2024 10:07pm
Mine was up to temp too.
And yes, as Blackwolf stated, it will only do it whenever you least expect it as well. Rolling Eyes
If the alarm happens to do off though (mine didn’t).
Then that suggests to me that the voltage has had such a drop that it has dropped out of expected range that the alarm would like to see, that is likely due to current with the starter motor that is intermittent though.
This brings me onto another idea, mines a 2.4 and I know Blackwolf’s has a 2.4 too.
Are any of the rest of you getting it too with a 2.2? or just 2.4’s?
LR did do some wiring changes to the 2.2, which might be to elevate starter motor voltage drop on cranking, 2.2’s are slightly up spec in wiring gauge.
Though off the top of my head I can’t recall if this was just alternator to starter, or starter to battery, but also likely includes the ground as well.
The larger the cable gauge, the voltage drop on cranking should be reduced and this then is an increase to the voltage that the starter sees on cranking compared to a smaller gauge cable. Which is good and as the voltage drop is reduced keeping the overall voltage on cranking kept higher, that will reduce the current draw on cranking. Higher voltage, means less current draw which is good within range.
I think voltage drop on cranking with Pumas is a bit of an issue, and I think part of that is that LR fitted slightly smaller gauge primary power cables than they should have, as I mentioned 2.2’s upgraded slightly, and LR did that for a reason.
I’m upgrading mine (the cables) soon, I will be able to see what voltages there is and what changes there is but these change dynamically anyway so accuracy in real world situations vary even down to things by ambient temperature.
But high voltage drop on temporary cranking is common, even down to 9v temporarily and the current draw on that is high.
A bad ground will have a similar effect, I’d rather see above 10.2v.
You can of course have a load present prior to cranking, but I doubt that this is an issue to people talking of this, I mean if you had a winch active, a high load device such as inverter or an an audio amplifier that could do it if active at point of cranking, but on mine this is off as I have these items switched so they only come on when alternator and engine is running.
Otherwise the HU will turn those on automatically if active, I have a switch so that the HU remote is only on when I want it to be, not just because the HU sends its signal.
But it still happens, so it isn’t this but any extra load on cranking would exacerbate the effect of voltage drop on cranking, which is best to have all loads off at all times before cranking.
Perhaps the ground path via transmission components and engine varies with temperature, back to the Alternator, overall it’s a solid reliable ground though, but there is a lot of current transfer especially cold cranking amps through there between the starter and the battery. No Guts, No Glory.
Post #1054904 16th Dec 2024 10:07pm
Ads90
Yes mine’s a 2.4. It’s a problem I can live with, but would be nice to know why it happens. It didn’t when new, maybe started 3 or 4 years ago.
If you notice any difference when you change your cables, please report back?
Post #1054929 17th Dec 2024 9:31am
Will do - I expect with in the next few months.
It tends to be a bit more common in autumn, winter, and spring but not exactly defined to that.
Again like you, I’m not too worried. Thumbs Up No Guts, No Glory.
Post #1054975 17th Dec 2024 7:13pm
Joshcank
United Kingdom 2010 Defender 130 Puma 2.4 HCPU Galway Green
Reading these posts it seems we all have a similar problem, but not necessarily occurring at the same time.
I am confident mine is directly related to outside temp. The injector connections are all dry, and the seals have only just been changed so it’s not that.
Mine never ever struggles with a hot or even remotely warm engine, starter spins the engine over at rapid revs no issue what so ever.
I have also recently changed the fuel filter, and when cranking the engine over to purge any air the start motor was spinning the engine over absolutely no issue what so ever at a decent speed.
I can pretty much guarantee, if I go to start on a cold morning the fault will occur. Really lazy cranking, till it dwindles down to absolutely nothing like the battery is dead. Quick on off with the key, and it spins over full speed and fires straight up.
Every logical solution to try, has a logical reason not to. I’ve resorted to carrying a boost pack just incase and will wait and see if the problem becomes terminal hopefully showing up the part at fault!
Post #1055155 19th Dec 2024 8:13pm
Joshcank
I did also had a new earth strap direct from the starter motor to the chassis earth, and this made no difference. To me, if a cable was at fault, a few degrees change in outside temp wouldn’t cause the problem to come and go. But I may be wrong?
Post #1055156 19th Dec 2024 8:16pm
Page 2 of 2 <12
