![]() | Home > Maintenance & Modifications > Ground fault? Voltage fluctuates while idling |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20599 ![]() ![]() |
How much does it fluctuate by?
+/- 0.2v each way is pretty normal, at idle it should stay quite stable really, but is normally a little lower than higher revs, but normally not by much. If the Alt is getting on, it might be the regulator. Do you have any variable electrical loads? I wouldn’t like to see much below 14.1v. Mine seems to sit around 14.4 to 14.6v, 14.5v is typical and quite static with no load or little load I should say. With a good 60A load plus a few hundred mV difference can be normal. I’d imagine if you are getting more than 0.5v drop or fluctuation with no real load on it, it might be time to try a new Alternator. GBR ⛽️🛢️⚙️🧰💪 |
T3DDY14 Member Since: 23 Jul 2020 Location: Kent Posts: 32 ![]() ![]() ![]() |
normally its at 15.8v roughly, but when it dips it goes down to around 13.6/8 and it gets worse when wipers or heater are on, and the trailer light also seems to turn on when it dips down. whats confusing is this is a year old alternator so surely it hasnt failed already
Will@LRW Member Since: 04 May 2019 Location: UK Posts: 193 ![]() ![]() ![]() |
One thing to check is that the alternator has the superseded smaller pulley to increase alternator RPM https://www.lrworkshop.com/parts/STC3202
The aftermarket alternator I bought had the larger pulley even though I bought the later part number LR Workshop Find a Defender's history and spec: https://defender.lrworkshop.com |
