Home > Td5 > LOF Clutch |
irishhawk11 Member Since: 07 Mar 2022 Location: Feldkirch Posts: 9 |
Hey there,
i just fitted a new clutch and have a lot more vibrations, especially when letting the clutch go and accelerating at around 1500-2000 rpm. I only have 60 Miles on it yet, but I am a little concerned. Did your vibration issues improve over time? Regards Benjamin |
25th Nov 2024 4:10pm |
B1_D130 Member Since: 15 May 2022 Location: Scotland Posts: 12 |
Hi,
Yes, the more I drive the landy, the better the vibrations got. I did not notice any real change in vibrations at low speed, but every so often when pulling away at junctions I get some low frequency vibrations, sometimes I get them when slowing down as well. Some of it I have attributed to slop in the drive train, as I have not looked at the shafts in a long time. To be honest, I was not truly happy with the noises and vibrations until I got to around 300 miles driven. As the clutch beds in, things do, definitely get smoother and less vibrations. Luke at LOF said the clutch would need about 500 miles to fully bed in. Up till recently, I was not even able to change gear smoothly, but it is getting smoother with time. |
25th Nov 2024 4:30pm |
BrickBox Member Since: 05 Oct 2021 Location: Wales Posts: 863 |
Once the clutch has bed in, the vibrations will settle down. 2008 2.4 110 Utility Station Wagon XS.
25th Nov 2024 5:41pm |
Thank you for your input
Hopefully this also works with mine. I will give a short update as soon I have hit 300-500 Miles |
26th Nov 2024 6:53am |
Ranger 6 Member Since: 17 Jan 2019 Location: Yorkshireman trapped in a Surrey postcode Posts: 205 |
The chaps building my 90 have said they won't touch a LOF clutch due to the issues they've had in the past. They said don't go cheap and they swear by Borg & Beck, which is what's being fitted to mine. 90 V8 CSW - 1988
27th Nov 2024 1:17pm |
bankz5152 Member Since: 02 Feb 2017 Location: South London/North Kent Posts: 2189 |
What issues did they have? Never had better customer service from anyone before!
They also arnt cheap, plus a borg and beck wont stand up to much more than stock power for long Instagram @defender_ventures Empire Tuning - Agent Last edited by bankz5152 on 27th Nov 2024 5:50pm. Edited 1 time in total |
27th Nov 2024 2:14pm |
Nidge Member Since: 27 Jan 2008 Location: Kildare Ireland Posts: 821 |
Yep me too, Top class service from Luke at LOF, Master cylinder had a slight leak, New one sent in the post by the end of the week, No issues since.
Have installed a few of his clutches too with no issues. Just make sure its lined up right and new spigot Bush installed, can be a pig to get out and some garages make take short cuts and leave the old worn one in place !! |
27th Nov 2024 5:17pm |
I can't say exactly what problems they had, but it was from experience of running a comp safari 90. I guess it was from the sort if use that one of those vehicles gets. 90 V8 CSW - 1988
10th Dec 2024 1:36pm |
fogbank Member Since: 30 May 2024 Location: Daylight Savings Posts: 8 |
Having had LOF on my Defender (clutch and brakes) and Borg and Beck parts on my Range Rover I know which one I'd class as cheap and its not LOF... |
10th Dec 2024 5:14pm |
Just thought I would post up a wee update.
I have now covered just over 950 miles on the new clutch. Driving behaviour is much better now. There is much less "jerk" every time I change gear. It has become more like it used to be. I still get a "clonk" most time I change gear, but I suspect this is due to worn halfshafts, which is my next job. I went through a spell of really weird noises coming from the front end. Strange "boings" and odd noises. The worst being a really weird "ZZZZZZZzzzzzzZZZ" type noise (Imagine shoving something solid into a spinning tire, that sort of buzzing noise that increases or decreases as you change speed) The noise seemed to be independent of the clutch, as whilst it went on, I could dip the clutch and it made no difference. I pulled over, could not see anything at all and when I continued driving, the noise did not come back again. Happened half a dozen times or so at different speeds. It was really loud too. Still have no idea where it came from, I am honestly not sure if it was due to the clutch bedding on, or unrelated, just strange that I have never had that noise in any of the defenders I have had over the years, and that it happened not long after changing the clutch. It has not made any noise like it in the last 2 weeks, so I am hoping it has settled down. Every so often, when idling, it does sound like someone has chucked a bag of spanners in a washing machine. The rattle from the bellhousing is quite bad. It is not all the time, but every so often, it is not noticeable from outside the landy, but very noticeable inside. Gives a noisy rattle when you turn off the engine. The clutch pedal has finally left the floor!! It used to be, the biting point of the clutch was about an inch off the floor, now it is closer to 2 inches. I had wondered if I should have changed out the master and slave cylinders, but I think I am ok. There is no slippage and as far as I can tell the clutch is working fine. The clutch pedal is still heavy. It is heavier than the original, even with the powerspring installed. I do not mind it, but I do now find it harder to drive the wife's VW, as I keep trying to put my foot through the bulkhead! All in all, I am still very happy with the new LOF clutch, but it has needed all of the covered 900 miles to bed in. |
16th Dec 2024 2:58pm |
Mo Murphy Member Since: 01 Jun 2008 Location: Letchworth Garden City, Herts Posts: 2271 |
Did your installing garage adjust the clutch master push rod after changing the clutch. It does usually require some adjustment to suit the new clutch and it's a normal step in the process of a clutch change.
17th Dec 2024 2:19am |
Hi Mo,
To be honest, I am not sure. I am guessing as the clutch pedal is so low, quite possibly not. I have gotten used to it, but where before the clutch used to activate around halfway of the pedal travel, it is now a case that the first 3/4 of the pedal travel does noting and it only activates towards the last quarter of travel. At a rough guess the clutch disengages when the pedal is about 2 inch off the floor. I might take the cover off and see if I can adjust it slightly. I still need to wind the pedal travel bolt back in, as I wound it all the way out to get the LOF Powerspring on. I left it out, as I was worried that if I wound it back in to its original location, I would not have enough travel to actuate the clutch. |
19th Dec 2024 3:40pm |
