Home > Td5 > TD5 Relay id in ECU compartment
Steve B
United Kingdom 2000 Defender 90 Td5 SW Caledonian Blue
Cannot find this anywhere, I know the yellow one which is hooked onto the side of the seatbox is for my fuel pump.
Does anyone know what the black one next to it is for?
I am looking for a 12v switched live (no power when key is off) in this seatbox area.
Many thanks for any replies.
Steve
Post #105194 6th Dec 2011 10:37pm
wslr
Usually 3 relays. One pump, one power to Powertrain ECU, one to glowplugs.
Post #105447 7th Dec 2011 9:17pm
Peter
United Kingdom 2005 Defender 90 Td5 SW Epsom Green
Just the answer I was looking for with my 2005 D90.
Been having starting problems and the suggestion from Gigglepin was to remove and replace each relay as the aren't the best, and cause problems. I was interested to know what they actually do. The starting or rather non starting problem appears to have ceased today after this probing.
However would like to know if this is a common fault and if there is a longer term solution to these relays.
Does anyone know if these are still the same set up and location in the latest Defender or has LR modified them and can I upgrade to that modification if any ?
Thanks
Peter
Post #133532 22nd Mar 2012 8:48pm
Laurie
A very nice main dealer electrician once cured a problem with my underseat relays.
He used a tiny pair of pliers to tighten the Lucar type connectors.
He told me that bad contacts in the relay sockets was the cause of most electrical problems.
He wouldn't even accept the price of a drink for his efforts.
Thanks Conway Land Rovers. Very Happy
Post #133536 22nd Mar 2012 8:53pm
Waldo
I believe that the Black relay is for the ABS, can't be 100% sure though Smile
Will Defender 90 XS TD5 (03 Reg)
Post #133615 22nd Mar 2012 10:40pm
excossack
I have the yellow one and a black one but no ABS/TC etc (Jan 1999 Td5) 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #133662 23rd Mar 2012 8:12am
Paul_1978
England 2004 Defender 90 Td5 CSW Zermatt Silver
If you do move / play with them, make sure you push the wires up towards the realys afterwards.
Like a previous post said, this is the cause of most of the problems, especially on the fuel pump relay. The contact between relay and crimp connection is not very solid and moves a bit when played with, then it will start to burn up and cause problems.
Post #133751 23rd Mar 2012 2:31pm
Zinke
United Kingdom 2003 Defender 90 Td5 HT Epsom Green
The white wire with the green stripe or rings connected to pin number 33 on the black ecu plug is a ignition controlled power feed that you can tap into. Any white wire with a green stripe or ring can be used for this anywhere in the vehicle.
Pete.
Post #134251 25th Mar 2012 11:46am
Steve B
Brilliant, Thanks Zinke.
Job for next weekend sorted.
Steve
Post #134324 25th Mar 2012 7:04pm
Zinke
That wire is only suitable for powering a relay though, you dont really want to be connecting anything to it direct.
Pete.
Post #134333 25th Mar 2012 7:42pm
Peter
Usual British standard of wiring. Think this is where the Jap motors exceed in their reliability in my exeperience.
Has there ever been an aftermarket fix for the relay faults ? As seems very common on TD5 's ? or is it a case of doing ones own re-wiring so you know its all ok.
Post #135321 29th Mar 2012 5:09am
