Home > Td5 > injectors all high impedance
Page 2 of 2 <12
htb2
Wales
Yellow one under the seat.
Post #1053833 4th Dec 2024 8:27pm
NickMc
alexatnd wrote:
derbywill wrote:
I was talking to an injector specialist who seemed pretty clued up on Td5 injectors and said the coil has a really tight tolerance and they cannot get them new anymore, so maybe yours just unfortunately fell slightly outside this limit, Better the change them, rather than recon them just to fail down the line.
Will
Yeah, so they had a set of reconditioned injectors that i've bought ... as per other reply on this thread.Will test with old injectors 1st to check ECU
Was talking to someone from Alive Tuning yesterday who said that theyve never found anyone who can recondition td5 injectors successfuly and my best bet would be to just try and find a working set.
A
BS Merlin Diesels do them!
I would be looking at the corrosion in that fuse box shouldn’t be that rusty
Post #1053849 4th Dec 2024 11:03pm
4RF RDS
Canada 2000 Defender 110 Td5 XS CSW Epsom Green
alexatnd wrote:
The joys of finding what realys do what in a defender. Gertie is a 1999 td5 110
piccies attached, 2 relays under drivers. seat, few bhind gearstick, some people suggested might be the green one ... the again local lan rover parts supplier said its the yellow relay under the seat ....
Oh my, Shocked I'd suggest you pull your fuse panel and have a good look at the back side and your fuse spade connections. I would suspect that they are quite corroded and in need of either cleaning or replacement.
Good luck 2010 Range Rover MkIII Autobiography Super Charged (Idris)
2003 Range Rover Mk III (Desmond FitzWilliam)
2000 Defender 110 CSW TD5 (CTX)
1992 Range Rover Classic (Lizzy)
1972 Series III 300 Tdi (Stanwood)
1967 MGB GT
Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats.
H. L. Mencken (1880 - 1956)
Post #1053920 5th Dec 2024 5:15pm
alexatnd
ok if i pull the yellow relay under the drivers seat, yes the fuel pump doesnt run ....but neither does the engine management light light up nor the glow plug light nor the alternator charging light
So wiring diagram says its rely R103 .... nowhere i can find tells you where it is physcally
time to browse lrworkshop.com ... Santa - 1977 Series 3 - new chassis, tub, disc brakes,SU Carb
Gertie - 1999 110 TD5 - like a Phoenix from the ashes back on road... almost
Effie - 2004 110 TD5 County
Post #1054018 6th Dec 2024 11:45pm
alexatnd
Success! its the green relay behind the gear stick
https://www.lrworkshop.com/connectors/defender-1999/C0730 Santa - 1977 Series 3 - new chassis, tub, disc brakes,SU Carb
Post #1054022 7th Dec 2024 12:40am
Page 2 of 2 <12
