Home > Modifications & Maintenance (L663) > Side step installation
110liam
I’ve bought some aftermarket side steps to fit to my new Defender 110.
I’ve watched lots of videos online on how to fit them and it seems a real faff to remove all the sills / break clips etc. Some videos only install the steps by cutting the sills in place and attach only using the underside 2 bolts, to avoid the need to attach the side bolts. The side steps from sidesteps UK also only use the 2 underside bolts.
Has anyone done this / how have they held up?
Post #1053523 1st Dec 2024 7:12am
DrRob
I have the ones from side steps uk as I didn’t want to remove sill covers etc.
Easy to fit and well made plus cheaper.
I’d buy again for sure 👍 MY25 90 D350 X-Dynamic HSE in Silicon Silver and coil sprung
1974 Series 3 Lightweight = "Millie"
Many Range Rovers and Land Rovers over the years 😂
1949 80" - still in family since 1975
Post #1053531 1st Dec 2024 9:50am
DrRob
Post #1053532 1st Dec 2024 9:51am
lightning
l attached mine using just the larger bottom bolts. They are very secure and l can't see why you'd fit the smaller side bolts.
Also it's much easier to get them off again if it's ever needed.
Post #1053538 1st Dec 2024 10:37am
isugoo
United States
I installed in 'right' way but if I do it again, I will prob. fit only the bottom ones as it's plenty secure and you can get it done in ¼ of time.
Post #1062340 8th Mar 2025 3:57am
