![]() | Home > Wheels & Tyres > Tyre pressure for defender 90 td5 with 235-85-16 |
Chicken Drumstick Member Since: 17 Aug 2020 Location: Near MK Posts: 861 ![]() ![]() |
We might not be in possession of all the facts, but motor cars have been around for well over 100 years. And the 110/90 for over 40 years. I think it is true to say of the tens of thousands built and the millions and millions of miles covered by the vehicles in that time, there is HUGE precedent to what does or doesn't work. You are also being hugely misleading with your comments about Firestone & the Ford Explorer, as Ford's eventual answer was: "Ford decided to lower the suspension and remove air from the tires to 26 psi compared to 35 psi" The opposite of what you are proclaiming. While Firestone was saying this: "Firestone sent several engineers to inspect the tires and concluded that normal passenger tires were being used in heavy conditions, on dirt roads, off-road, and under heavy loads." https://en.wikipedia.org/wiki/Firestone_and_Ford_tire_controversy |
drakes Member Since: 09 Oct 2009 Location: Hexham Posts: 113 ![]() ![]() ![]() |
Just use some tyre chalk across the tread and go for a short drive to see the wear pattern
