Home > Td5 > Td5 maf sensor cost
Betsy
 1999 Defender 110 Td5 HT Coniston Green
Td5 maf sensor cost
Good evening
Looks like I need a new maf sensor, having looked there is a big difference between genuine at £80-100 and aftermarket which paddocks do one for £20 something
Is the extra £60 odd quid worth it
Thanks
Post #1053020 26th Nov 2024 5:00pm
bankz5152
Map it out instead. Not worth the cost and itll fail again in a year. Only the genuine/vdo/siemens ones work. Instagram @defender_ventures
Empire Tuning - Agent
Post #1053022 26th Nov 2024 5:08pm
TexasRover
I do like all parts of my car to work as intended, but agree that changing a non-working out with an expensive Siemens MAF did not make much of a difference.
I recall that data is mainly used to operate the EGR system??
Post #1053029 26th Nov 2024 5:54pm
bankz5152
Minor control on fueling, fairly pointless item. They where not fitted to every TD5, the ROW spec TD5s did not have them. Instagram @defender_ventures
Post #1053031 26th Nov 2024 6:06pm
Betsy
Thanks chaps
I’m going to put the multimeter on the old one to check it.
It’s struggling to want to go much past 50mph, iv swapped the injector harness and cleaned out the red plug numerous times, I’ve freed up the actuator arm, the latter got rid of the kangarooing it was doing under hard acceleration
I disconnected the maf tonight and took it out for a brief drive and I think there was a improvement but couldn’t fully tell as it was only a country lane
Post #1053062 26th Nov 2024 10:43pm
