Home > In Car Electronics > Defender 2012> OEM specific to ISO loom connector lead.
Page 2 of 2 <12
jpboost
United Kingdom 2014 Defender 110 Puma 2.2 SW Keswick Green
An update for anyone looking at this:
if anyone is struggling to find anyone who stocks autoleads anymore (have they ceased trading?).
The alternative part number for the post 2012 defender ISO loom is CT20LR04. It seems much more widely available and I believe is made by Connects2.
EDIT: So it (CR20LR04) arrived, and while the plugs fit, the pins are not in the right position. It was quite straightforward to de-pin and reassemble in the correct order (using the original LR/Alpine plug as a reference).
A bit more digging, and I think that the correct part is actually CT20LR06, but as I've just reconfigured the one I bought, I've not bought/tested the updated partno.
Post #937348 12th Jan 2022 1:28pm
circlethewagons
Australia 2015 Defender 90 Puma 2.2 HT Aintree Green
Hiya, I have the lead CT20LR06 - but I'll be Censored if I can get the grey connector to fit, I dont want to bend pins. Is there a trick to making it fit?
Post #1052472 22nd Nov 2024 1:45am
It is probably the wrong part.
If you feel capable, you can always manually fit DIN ISO male plugs anyway, that is universal and also removes the need to have any adaptors anyway.
2.4’s were DIN ISO as standard which matches the vast majority of aftermarket head units. TheThunder Rolls🇬🇧🇺🇸
Post #1052494 22nd Nov 2024 9:48am
circlethewagons
After some random jiggling - it fits - I have my $29 Alibaba special working!
Post #1052498 22nd Nov 2024 10:14am
That’s good, sometimes the pins get a bit out of alignment in transit. TheThunder Rolls🇬🇧🇺🇸
Post #1052502 22nd Nov 2024 10:35am
Page 2 of 2 <12
