Home > Technical > Defender front door latch: what does this arm do? |
L110CDL Member Since: 31 Oct 2015 Location: Devon Posts: 10739 |
I've not come across this problem before, is it a 300 Tdi door, if so would it help you if i was to take my door card of and have a look for you, if so i can do it this weekend ? 1996 Golf Blue 300Tdi 110 Pick up.
Keeper. Clayton. |
20th Nov 2024 8:26pm |
Dr Phibes Member Since: 24 Apr 2024 Location: Melbourne Posts: 17 |
Thanks but it’s a TD5. I am going to replace all of my door actuators with eBay ones, and bypass the AS10 being removed. I don’t think the position of that arm will matter when the door is closed.
20th Nov 2024 8:34pm |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5679 |
That is the lock isn’t it? Goes up to the door button inside.
20th Nov 2024 8:36pm |
No. The rod is one I added. I thought at first that internally it connects to the same mechanism as the door opening latch, but the door stays closed with it up.
20th Nov 2024 8:40pm |
Click image to enlarge |
20th Nov 2024 8:43pm |
Click image to enlarge Best guess is that it is for a different variant, normally disconnected in td5 defender. |
20th Nov 2024 8:59pm |
rustandoil Member Since: 08 Sep 2012 Location: Cotswolds Posts: 738 |
Does this help in any way...?
2005 TD5 Click image to enlarge |
21st Nov 2024 7:57am |
