Home > General & Technical (L663) > Key Fob Not Working |
Miran Member Since: 14 Feb 2022 Location: Portoroz, Slovenia Posts: 14 |
I have the same problem. Not regularly, every couple of weeks or something. Car is parked on same spot. No power lines in vicinity.
Changed the remote battery, it didn't help. Contacted the dealer - no definite answer or advice. Followed the advice from somewhere on the net and repeatedly locked and unlocked the car with remote. Same stuff. I (unwillingly) became used to it. Thank you ODPA, I' try also your advice. By the way: what is "KVM"? Miran L663 200 S 3,0 |
27th Sep 2023 4:40pm |
Lockley Member Since: 15 Feb 2023 Location: Herefordshire Posts: 16 |
Thanks ODPA. I had the same problem today. Thanks to your guidance I checked the fuses. They both looked okay, but I changed the five amp one anyway, and it all came back to life. However, when switching the old five amp back in again, it has remained working. It seems like removing and replacing the fuse is somehow resetting the KVM. Simply clearing the faults on the Gap tool did not do the trick. L663 D300 SE MY22. |
7th Dec 2023 6:36pm |
ODPA Member Since: 06 Jul 2023 Location: Northwest Posts: 86 |
Glad my experience helped someone else. Interesting the fuse was fine. I had
Wondered if that was the case as you described but had not taken the time to test further. Great additional info. |
8th Dec 2023 6:32am |
Ajay(UK) Member Since: 13 Feb 2021 Location: Arundel, W.Sussex Posts: 78 |
I thought it would be good to bump this post back up the order as I was suffering from the exact same symptoms this morning.
For no apparent reason the keyless entry stopped working on our 22MY Defender and the car wouldn't start. Doors could be locked and unlocked with the buttons on the remote but the engine would only start with the key placed on the slot under the steering wheel. I checked both keys but neither would work correctly. So thanks to this forum again and specifically ODPA's post, I checked the two fuses in the rear which, for the record are #43 for the 20amp and #57 for the 5amp and even though the 5amp one looked ok I changed it with one of the spares and it worked, both keys now operating correctly And there was me about to LR Assist Thank you again ODPA, problem solved Cheers, Andy. 22MY Defender 110 X Dynamic HSE D250, Gondwana Stone with too many options! 2022 Range Rover Sport D300 Dynamic Autobiography, Firenze Red with Black Pack. Gone: 2015 L405 SDV8 Autobiography, Indus Silver with Black Pack. Gone: 2014 Discovery 4 HSE Luxury Firenze Red |
19th Nov 2024 1:04pm |
Glad my experience helped you out.
19th Nov 2024 3:48pm |
