![]() | Home > In Car Electronics (L663) > MY25 Wireless Charger |
DrRob Member Since: 29 Mar 2017 Location: Hampshire Posts: 222 ![]() ![]() |
![]() I used a lead ![]() 1974 Series 3 Lightweight = "Millie" Many Range Rovers and Land Rovers over the years 😂 1949 80" - still in family since 1975 |
ruben Member Since: 04 Feb 2021 Location: ASTURIAS Posts: 232 ![]() ![]() |
I don't use it either, neither this one nor any other, for the same reason, use the lead, I only leave it for exceptional moments! and It is very rare that I need to recharge in my car, phones now hold a charge for a very long time!! although there are people who use this charger as a storage for their phone and it charges continuously by default, and its not good idea! Defender 110 SE I6 D250 23MY
ExDiscovery 3 TDV6 SE |
A1C6 Member Since: 15 Oct 2024 Location: Australia Posts: 58 ![]() ![]() |
I reckon it'd be the camera bump. On those pro phones the cameras protrude so far out of the phone that, in some cases, the waves from the wireless charger (or whatever they are - I don't understand witchcraft) can't reach the coils? inside the phone. But again, as other people have said, I wouldn't advise using the wireless charger. |
DFNDER Member Since: 02 Oct 2023 Location: Perth WA Posts: 136 ![]() ![]() |
Wireless chargers are nothing more than a magnetic coil. No witchcraft. Either remove the phone from its case, or place face down. It needs full surface contact for the low powered mag field to carry the charging current to the battery. Face down works for my Android S24 with quadlock case.
graemesmith1960 Member Since: 03 Sep 2021 Location: West of Scotland Posts: 79 ![]() ![]() |
Same problem. Is there any way to check if it is faulty? Doesn't matter what phone I use it seems to only work for 10% of the time. At the start of the day if it kicks in the phone will happily charge every time I put it in the tray that day. Next day it won't work at all. Really useless. Defender D350 X-Dynamic HSE 110 MY25 Carpathian Grey
F-Typical Member Since: 05 Sep 2024 Location: Hereford Posts: 49 ![]() ![]() |
16 Pro in an Apple case charges just fine in mine. So the camera bump doesn't appear to be the issue.
15 Pro in an Apple case. I've done a lot of experimenting today. The case doesn't seem to make much difference. The only way it works every time is to place the phone in the tray before starting the engine! Defender D350 X-Dynamic HSE 110 MY25 Carpathian Grey
