Home > For Sale & Wanted > TD5 ECU (Remapped?) Wanted |
Dave-H Member Since: 08 Feb 2011 Location: Surrey Posts: 1507 |
Give Porny or Ada on here a nudge [IRB Developments] ..... Based near Tamworth.
Failing that .. Gary [Alive Tuning] should be able to help? Guns and Landrovers .... anything else is irrelevant. |
6th Dec 2011 8:28pm |
markb110 Member Since: 22 May 2010 Location: Guildford Posts: 2644 |
Hi Amond
Was that the reason for the misfire on Saturday? Mark |
6th Dec 2011 8:46pm |
amondeggs Member Since: 06 Mar 2011 Location: Telford Posts: 452 |
Hi Mark, ECU failed big time, looks like a spike from something took the ECU. I have the original one fitted at the moment so car is a very different animal. I think water / mud got into the bell housing despite the wading plug and caused havoc witht the crank sensor Would this happen
When I removed the wading plug tonight there was mud in the bell housing that was not there before. How would this get in as I need to stop it Any how now looking for new ECU to get performance back |
6th Dec 2011 9:52pm |
Alive Tuning Member Since: 01 Mar 2010 Location: Louth Posts: 610 |
Speak to Rick at Monster Tuning in Bridgnorth. Tel 01746 714 703, as he is the closest distributor I have to you, and will be happy to assist. It's better you deal with us using your local ALIVE dealer.
I have stacks of ECU's on stock. If you give Rick your old ECU, I can clone all the settings across to the new one so it will plug in and work straight out of the box. |
9th Dec 2011 1:49pm |
