![]() | Home > Tdi > 300Tdi oil seepage |
Fossil Member Since: 23 Aug 2015 Location: Bolton Posts: 17 ![]() ![]() ![]() |
I think the vacuum pump mounting bolts are through bolts(!) The pumps are notorious for leaking where they are riveted together, and it is possible to fix that by replacing with M5 bolts. The welch plug is also known to leak and I don't think you can do much about that.
jfh Member Since: 08 Jan 2014 Location: West Coast Posts: 364 ![]() ![]() ![]() |
Thanks.
Pump is good, still monitoring the pump to block bolts. Lift pump priming lever is part of the problem. |
