Home > Puma (Tdci) > Mirror Arm
AKL
United Kingdom 2012 Defender 90 Puma 2.2 SW Firenze Red
Mirror Arm
Hi Everyone - just wondering whether the bit that I have circled comes off as the mirror arm is moving quite a bit - not sure how to tighten - thank you.
Post #1051600 13th Nov 2024 2:44pm
Dinnu
I know the bottom cap can come off and there you can see a spring that pulls the assembly into indents. However unsure if there is an adjustment to preload the spring further. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #1051604 13th Nov 2024 3:02pm
Yes, the top plug can come out (the easiest way to remove it is to remove the bottom one and then use a long thin thing to push out the top one from below) however the mirror arms are 100% non-adjustable so removing the plug achieves nothing.
In practical terms the only solution to a wobbly arm is to replace the arm.
Post #1051605 13th Nov 2024 3:42pm
philippr86
Germany
Yes, eaxactly as blackwolf said. I also had quite a bit of play in the hinge and thought I just buy new one. So I opted for Allmakes ones only to find out that they did have even more backlash from new. So I took the aftermarket one apart and found that they have been cutting corners in the design. A bit of machining was involved on my lathe, but now I can take them apart, tighten the spring as I wish and all good. Unfortunately I think I did not take any pictures doing this. If I do find any, I will upload them...
Post #1051728 14th Nov 2024 11:54am
AKL
Thank you - will try this and see what happens.
Post #1051730 14th Nov 2024 12:48pm
AKL
Thank you will have a look on the weekend - over time by putting mirrors in and out whilst parked has caused them to wobble more. Just the passenger side though which is strange.
Post #1051731 14th Nov 2024 12:50pm
AKL
Thank you will have a look online
Post #1051732 14th Nov 2024 12:51pm
