![]() | Home > Maintenance & Modifications > Puma front washwipe pipe removal / refit? |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5846 ![]() ![]() |
It could easy (frequently is) the one way valve that is in the pipe. Often found beside the heater box between it and the wing. Worth a check
Stacey007 Member Since: 25 Sep 2015 Location: Cheshire Posts: 3817 ![]() ![]() |
Hello
Many thanks, got home tonight and head straight under bonnet. Found two washer pipes worked out which was front. Pulled it from the connection and checked it was free, it was as water poured out. Then took the connector out and just refitted. It worked great What I noticed is the connection has a ball in it like a one way? Why and why does it even need the connection and not be straight pipe? It looks like the attached with a little ball at the end. At least I know what to look at may swap for the Csi part anyway as still not great (compared to modern stuff) but better 😀 Thanks ![]() Click image to enlarge |
Many of us remove the one way valve as in cold weather it is water in the pipe that freezes, and with no one way valve it only takes a couple of seconds longer for water to flow.
