![]() | Home > In Car Electronics > Intermittent electrical issue - key fob now won't work |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20643 ![]() ![]() |
Battery could be going under due to parasitic drain or age, or more likely ground issue or loose battery post or transmission ground stud. TheThunder Rolls🇬🇧🇺🇸
Ianh Member Since: 17 Sep 2018 Location: Essex Posts: 2160 ![]() ![]() |
I agree with custom90, loosen negative cable on battery post , tap it down gently and re tighten. Also check other main earths. It’s very likely one is loose or making a bad contact.
Else if it’s the original battery it is likely that it’s no longer holding sufficient charge, put a meter on the battery to see if it has circa 12.4Volts, if a lot lower then it’s likely a failed battery. If you have access to another vehicle and jump leads, or something like a Noco jump starter, you can see if it will jump start. |
