Home > Tdi > Sound from 300TDI
jackie-o
Sweden 1998 Defender 110 300 Tdi CSW Coniston Green
Sound from 300TDI
Hi all,
New to this forum and have had my 110 300 tdi csw for almost 48 hours now.....
Would anyone be able to help identify the source of this noise coming from the engine?
It increases with RPM. My first guess was a belt but worried it could be a bearing. Car was just driven 150 miles from Spain by former owner who claimed the sound was present the entire time.
I posted 2 videos to youtube as I could not find a way to upload here.
[url]https://www.youtube.com/shorts/NYPmg623FUA
[/url]https://www.youtube.com/watch?v=_zF42kVIGQs
Many thanks in advance!
[/url]
Post #1051269 10th Nov 2024 8:52pm
landy andy
Belt tensioner would be a starter to check. Sounds like drive belt derived noise.
Post #1051270 10th Nov 2024 9:11pm
jackie-o
@ Lany Andy Thank you! I have it booked for a look over at my mechanic on wednesday, do you think its safe to drive until then?
Post #1051271 10th Nov 2024 9:18pm
landy andy
Yep. I’m not hearing enything that particularly worries me. It is a Landy. It’ll keep going. It’s just telling you it wants some of your money and time. Thumbs Up
Post #1051272 10th Nov 2024 9:31pm
sako243
Just double check the crank pulley. I had a squeak which I thought was the tensioner. On replacing it I noticed the crank pulley was wobbly. Rubber damper had collapsed in it - if so replace ASAP as it'll snap the crank (having snapped done two I think I know)... Ed
82 Hotspur Sandringham 6x6
95 Defender 110 300Tdi
Post #1051276 10th Nov 2024 10:25pm
jackie-o
@sako243 thanks for your reply! Where would this be located? It sounds as tho the noise is coming from the front left hand side of the engine. Mine is a LHD if that makes any difference?
@Landy Andy; hope you are right Very Happy
cheers!
Post #1051282 10th Nov 2024 11:18pm
sako243
Big pulley at the bottom of the engine. One big (24 or 27mm, can't remember off the top of my head) bolt holding it on. Easier to have a look from underneath.
If there's rubber dust around it I'd be concerned as well. New pulleys aren't dear but easier to replace with the radiator out. Ed
Post #1051283 10th Nov 2024 11:20pm
