![]() | Home > General & Technical (L663) > Throttle/shifting issues at low speed (Defender 90 '25) |
lightning Member Since: 23 Apr 2009 Location: High Peak, Derbyshire Posts: 3028 ![]() ![]() |
I would wait until you've done a few miles before complaining to the dealer about the Defender's transmission.
My D250 was similar when l first got it but slowly improved over time. Also in slow moving traffic l find it's smoother to move the transmission lever over to "S" and manually select second gear. |
DFNDER Member Since: 02 Oct 2023 Location: Perth WA Posts: 140 ![]() ![]() |
It's the adaptations in the transmission ecu. As said you need to drive it more and also in manual mode. The ecu adapts to your driving style and relearns the factory set shift points.
eno Member Since: 15 Apr 2024 Location: Qld Posts: 42 ![]() ![]() |
I felt the same thing in a 90-P400 demonstrator vehicle that I test drove. It was quite off-putting. Yet in a 110-P300 I test drove the throttle response was good, as would be expected. And the 90-P300 I purchased is good too.
In the P400 I got the feeling it was more engine response related than transmission related. Maybe to do with the electric supercharger engagement, or something like that |
difflock1000 Member Since: 10 Nov 2024 Location: Arabia Posts: 2 ![]() ![]() ![]() |
Thanks for the feedback everyone. After driving the car a few more weeks in S mode, I feel that it's now more tolerable and improved slightly. Required a bit of adjustment in my driving style too. Regular D mode is still undrivable and a lot more laggy, and I wonder if I have to "train" that too.
Also been reading that this is possibly the turbo lag. |
lt shouldn't have any turbo lag as l think it also has a supercharger.
Mine was sometimes "all or nothing" on initial acceleration when it was new, but it gradually improved with mileage. ln certain circumstances the transmission seems to disengage, probably for economy reasons. Then if you are not careful you can get a sudden surge of power a second after you accelerate, when the transmission re-engages. |
Flinders Member Since: 17 Feb 2024 Location: West Yorkshire Posts: 73 ![]() ![]() |
My D350 was very similar to this when I first got it. I felt like I was driving a ropey fiesta again with a dodgy clutch!
It went to the dealers for the repair to the squealing ventilation and the rolling back in drive. They did agree with the drive and they fixed the gear change by reprogramming every gear from scratch. It feels so much better, despite not being able to resolve the rolling back and squealing ventilation….. oh and the start button problem! I’ve rejected the car and it gets collected tomorrow for the other problems but at least the gear change has been much better! ![]() MY25 Defender 90 D350 X Dynamic HSE - Boris - REJECTED ![]() MY18 Discovery 5 3.0ltr TD6 HSE Lux - Derek |
XplusYplusZ Member Since: 16 Aug 2021 Location: UK Posts: 525 ![]() |
My D250 110 has had the same behaviour from new. The LR Assist mechanic told me it's a software thing. I have found that I can mitigate/work around it by being more careful when slowing then accelerating (eg. red lights turning to green, roundabouts, etc). It becomes more natural.
I haven't ever tried driving around in S mode, but will give it a shot. |
I think it's because the transmission will often disengage on a trailing throttle or as you approach a standstill
Then, if you suddenly apply power, the revs shoot up and initially nothing happens. And then there's a thump and a surge of power as the transmission engages. l've driven other automatic transmission vehicles and they do it as well, it's all down to economy and emissions. lt's a shame the disengaging can't be mapped out, as it doesn't always happen and in those cases it's perfectly smooth. lt's possible to drive around it by preemptively applying a little gas before you need to accelerate, to re engage the transmission. It's smoother in ECO. And also improves with mileage l assume the transmission tries to adapt. ln slow moving stop/start traffic, try selecting "S" and then pull back to engage "2" this makes for much smoother progress at low speeds. And turn off the "hold" function. |
