Home > Puma (Tdci) > Revs drop with stationary throttle |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17353 |
That does sound like VCV if there are no DTCs suggesting otherwise.
10th Nov 2024 2:13pm |
andy63 Member Since: 30 Jun 2023 Location: north east Posts: 511 |
Are you able to look at rail pressure and boost pressure while it's doing this..
It does sound like it's over fuelling.. Does the vcv valve default to open and when powered it limits fuel..or the other way round.. I always thought it defaulted open, but I've been looking at one recently off a ford connect i think it was..it appears to need power to open.. Stuck open would give you high rail pressure at low demand i suspect and give you the symptoms you are describing.. |
10th Nov 2024 2:32pm |
Phillywilly72 Member Since: 29 Apr 2024 Location: Wiltshire Posts: 63 |
I’ll try and get those readings read at the same time thanks
10th Nov 2024 3:10pm |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20300 |
Try checking the Turbo actuator too, light lube the pivots in case of sticking.
If the VCV is sticking, it might be slightly over fuelling, and more likely if revving it which isn’t ideal from cold anyway too much, but it tends to under fuel more. Good luck tomorrow, but as mentioned no DTC’s are produced from the VCV even if it’s in a dire state. Blackwolf - Sounds about the sort of figure that LR would go for, I think you mentioned it before. Perhaps the throttle works the way it does as a kind of safety measure, alongside the anti stall as well when that’s active. ⭐️⭐️God Bless the USA 🇬🇧🇺🇸 ⭐️⭐️ |
10th Nov 2024 5:26pm |
I’ll give an update when it’s been on a reader and swapped the vcv. Thanks
10th Nov 2024 5:45pm |
I ordered a Denso part but this turned up, anyone had any experience with this make?
Click image to enlarge |
12th Nov 2024 1:56pm |
Update- All back together and problem gone. SCV/VCV was the issue. Thanks all contributors
16th Nov 2024 12:57pm |
