Home > Off Topic > HETAS advice needed
walfy
HETAS advice needed
Are there any HETAS engineers on here that are ticketed to fit woodburners?
Previously I had a woodburner fitted, the body of the burner sat on a inbuilt to the fire pedestal. It sat on a piece of 12mm thick glass which sat on the laminate floor.
So I fully understand the reason for the glass.
I have now changed my floor to concrete slab and stone tiles. The HETAS engineer that came to recommission my burner said I had to have a hearth fitted again.
Why do I need one, if the embers fall on a stone tile then there is no issue.
Without the glass hearth the burner looks a lot better on the stone tile floor.
Looking online at the regs, I can't make sense of them where a stone tile floor is fitted.
Anyone offer any advice? 110 D250 SE HT
110 USW SOLD
RRE HSE Dynamic Gone, wife killed it
VOLVO XC60 R Dynamic with some toys
Polaris RZR 900XP SOLD
Post #1051134 9th Nov 2024 9:18am
Bowbearer
United Kingdom 1985 Defender 110 200 Tdi SW Auto Baltic Blue
I’m not a HETAS engineer but used to work in planning with building control.
They said I could fit mine myself in line with the manufacture instructions and guidelines on web.
A hearth is not mentioned. It has to stand on a non combustible material that must protrude a certain measurement out from the front doors. This would give you the size of harth you would require if it was on a wooden floor.
Solid floor should be fine.
Personally I found installers to be very cagey about how to fit as I think they know how easy it is.
Post #1051137 9th Nov 2024 10:03am
Barneyboy
England 1986 Defender 90 2.5 n/a Diesel ST Nato Green
Hi, I’m not a HETAS engineer but we have had 2 woodburner fitted in the last couple of months and both have had HETAS certificates issued, I have added pics below, as you’ve commented it doesn’t make sense and I think Bowbearer has hit the nail on the head, i hope you get sorted without too much of a faff Thumbs Up cheers Paul
Post #1051165 9th Nov 2024 4:18pm
julian
United Kingdom 1994 Defender 110 300 Tdi CSW Alpine White
Document J of the buildings regs is freely downloadable, and covers all the details in a fairly easy to read way.
Hetas, however, seem to make up their own rules as they go along.
My advice would be just to get building control in, if you need to. It will be way simpler. If it's compliant with doc J, it will pass, and if it is not, it will not. It's clear cut, not "fuzzy" and made up on the spot.
Hetas will frequently install stuff that's non compliant under doc J, if it's easier for them to do so, as they sign it off themselves.
You can tell I have little respect for them.
Post #1051182 9th Nov 2024 6:54pm
MarkBrown
Wales 1983 Defender 110 Other HT Auto Keswick Green
When I built my place ten years ago I fitted one burner and had a hetas registered chap I know fit the second one and checked the first, then signed them both off. When the building inspector came he didn’t even look at them, but I must of had to send off the certificate to get the final sign off from the council. The regs are simple to understand, distances from walls, beams etc, flue sizes, cold air duct and so on. The hearth had to be a certain distance from the front, not that much from memory ( 8-10 inches?) but I can’t see why it would make any difference on a concrete floor anyway, unless it was carpeted - like mine is. The impression I got from building control was that they like the self - certified certificates ( part P, hetas etc ) as they don’t actually understand most of the regulations anyway. 1983 110 automatic OM606
Post #1051185 9th Nov 2024 7:25pm
lohr500
Barneyboy wrote:
Well that's one way to make the EP90 a bit easier to pump!!!!
Post #1051194 9th Nov 2024 8:27pm
BadgerWaz
The hearth should be a minimum of 12mm thick but this would then require a fender to prevet any rugs being laid over the hearth.
Otherwise the hearth should be 50mm thick.
The depth of the hearth wants to be 300mm minimum.
Any part of the stove should be a minimum of 150mm from any combustable materials (for example: any skirting board used either side of the fireplace).
You can use Oftec or Local Authority (Council) to register with buildings control (to adhere to Part J) to avoid paying through the nose to a Hetas fitter. You should also notify your home insurance company.
An issue with downloading regs is making sure you are reading the latest revision, this usually means paying a subscription.
Post #1051195 9th Nov 2024 9:33pm
Barneyboy
lohr500 wrote:
Rolling with laughter Thumbs Up
Post #1051205 10th Nov 2024 7:12am
walfy
Many thanks for all the advice, the instance above is for a burner set in a fireplace which has different regs to freestanding from my reading.
The reason for the HETAS engineer is that the refitting of the burner is part of an insurance claim, flood not fire.
We went from a wood floor to a stone tile floor.
 110 D250 SE HT
110 USW SOLD
Post #1051229 10th Nov 2024 11:14am
