![]() | Home > My Defender > 200Tdi 110 |
Caterham Member Since: 06 Nov 2008 Location: Birmingham Posts: 6324 ![]() ![]() ![]() |
they most definitively don't look rubbish. they look great (just not my choice
![]() keep up the great work ![]() |
bodstruck Member Since: 09 May 2020 Location: Wiltshire Posts: 949 ![]() ![]() |
Doors fitted. It took some fettling but I got there in the end. I'd say I am 95% happy with the alignment but there is nothing further I can do to get the shoulders completely in line. It is pretty good though.
Fitted the rear arch infil panels and then refitted the arches. I had deliberated over painting them body colour but decided that original black plastic was a better bet given the use of the vehicle. I picked a set up at the Newbury Spares day a while ago for about £30. A good splosh of bumper and trim polish and elbow grease and they have come up really well. Next was fitting the remainder of the mud shields. I wanted to wait until the arches were on so I could get a good coat of underbody wax in there beforehand. I have Dinitrol and Waxoyl but decided to use Lanoguard this time. I opted for this for the ease of use and application. Time will tell how well it protects but applying was really straightforward, no compressor needed and it is thin enough in mild conditions to coat really well. Fronts: ![]() Click image to enlarge Rear: ![]() Click image to enlarge And the removable rear mudlfaps that come with the other kit I fitted - I like this idea and they work well. ![]() Click image to enlarge And then out of the garage ready for the wheels to be refitted. I have been delaying this as once the wheels are on it cannot go back into the garage. ![]() Click image to enlarge Wheels ready to fit: ![]() Click image to enlarge And the car mobile again on its way for MOT ![]() Click image to enlarge Unfortunately it failed, but I knew it was going to ![]() A set of new HD track rod ends and silicone boots are on their way from Gwyn Lewis, new washer pump should be here today and I'll tighten up the bearings this weekend. Fingers crossed it should then be roadworthy again next week ![]() Still a fair bit to do. Snorkel, winch, second battery install, interior electrics (lights, EW, CL, heated seats) carpet the rear sides, fit cargo cages, shelf and door table, fit the wright offroad matting. But it will still be usable while I do all of this which is great. Ideally I would repaint the sliders and winch bumper. But they are both galvanised and they will only get scratched again so I may not. |
Procta Member Since: 03 Dec 2016 Location: Sunderland Posts: 5242 ![]() ![]() |
that's a work of art and a proper rebuild, not like the F88kin shi8t that my dad paid 30k for and still putting money into, and finding issues with!
Mot failure wise, i wouldn't worry, see those as just ironing it out. My rover metro me and my dad rebuilt failed on a two sheet of paper ![]() ![]() ![]() Looking at the quality of my dads rebuild, me and him could have done a bloody better job, we have done it in the past on our own, with out any forum help practically ![]() Success is 90% Inspiration and 4 minutes Preparation # you can make it! |
I hope your Dad gets his motor sorted and can find a way of enjoying it. Sometimes tricky not to associate the car with the shoddy garage. Good luck
![]() I fixed all the issues last weekend. New track rod ends, silicone boots, new washer pump and tweaked the bearings up a bit. MOT passed on Monday. While greasing the props I did realise the front diff pinion bearing is rough when turning. It is a 10 spline diff so I think time for an upgrade of some sort. Probably just to 24 spline internals and new cvs and shafts. I seem to have a mass of electrics to sort which I am procrastinating over. Windows are a priority. Then I think central locking, heated screen and heated seats. In that order. |
L110CDL Member Since: 31 Oct 2015 Location: Devon Posts: 10894 ![]() ![]() |
Great she passed the mot, i would put the heated windscreen to the top of the list as i wouldn't be without mine now after putting of for a while
I have all the switches, relays and wiring now so once it stops being so flipping freezing I can set about sorting the windows and screen. One issue with it being out of the garage now is that I am limited by daylight hours and weather, which are short and cr@p at the moment
![]() Not being able to wind down the windows, even a crack, is more of a pain than I thought it would be, I find that you often need a bit of fresh air circulating to keep the screen and windows clear. Maybe this weekend will be better ![]() |
Took it for a post-Christmas trip on the lanes around Bath. I thought it would be a gentle pootle on some nice wide lanes, turned out to be a bit brutal, and very scratchy on my new paint job
![]() ![]() ![]() Click image to enlarge ![]() Click image to enlarge Good day out though ![]() First order of business was trying to sort out the old wiring. The PO had done a very thorough job of the auxiliary wiring - everything nicely fused, cables well protected and liberal use of relays. The one problem was - nothing was labelled and the wires were impossible to trace. reluctantly, I decided the best thing to do was to pull lots of it out and start again, this time creating new wiring diagrams and recording what went where. To make sense of this: ![]() Click image to enlarge I had to pull out all of this lot: ![]() Click image to enlarge ![]() Click image to enlarge I don't really have any pics of the results right now but I now have a working heated windscreen, electric windows and central locking. I need to do a little more tidying of the wiring then the next jobs will be to fit the second battery, wire up the heated seats and finish the rear wiring for work like, interior power and the reversing camera. Then the seatbox matting and refit the headlining. I think that will do me for a little while as I just want to use it more now. The other jobs can wait a little longer. |
Good you had a great day out in the lanes and that was some spaghetti your having to sort out
Difficult to take decent photographs of the latest progress.
Headlining is in. I decided to abandon the fir tree clips and fitted M6 rivnuts to the roof and fixed the headlining using countersunk SS screws and black conical aluminum washers. ![]() Click image to enlarge Mud roof console also fitted. Again, I used rivnuts and screws where I could. This also required new wiring for the interior light (a Mudstuff one). I have put wiring in all 4 door pillars but not put switches in the rear just yet so only switched from the front doors. Certainly good enough for now though. ![]() Click image to enlarge I had previously sprayed the rear window trims in fine texture raptor. First I installed the brackets for the high level shelf and then fitted the window trims. New clips were required for the rear 1/4 windows but they all went in well and look very smart. ![]() Click image to enlarge I also wired up the Scenelight and reversing camera. The light I put in place of the rear washer. I have run the washer tube to the rear but for now I have decided that as the rear window is very darkly smoked and it will have a grill and bags on it i won't fit the wiper and washer. ![]() Click image to enlarge The camera is offset but the plan was to just give a general indication of what was to the rear rather than a detailed guide for reversing. This feeds to a single din 7" screen android auto head unit fitted into the raptor dash console. ![]() Click image to enlarge It is a compact unit with a good screen. The wired and wireless android auto work well. ![]() Click image to enlarge ![]() Click image to enlarge |
farley Member Since: 13 Feb 2025 Location: Sheffield Posts: 3 ![]() ![]() |
Very nice, winch looks great too.
TexasRover Member Since: 24 Nov 2022 Location: Paris Posts: 1156 ![]() ![]() ![]() |
Destination London Ultra Low Emission zone? Optimistic?
Good point
is there adjustment in the bonnet and wings? my dad has a right old gap on his driver side, to the point you can see the bottles, inside the engine bay Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
There is some.
I recall there being some adjustment in the M6 bolt holding the wing top to the bulkhead. Also the front of the bonnet can be adjusted to close the gap. |
