Bomber82
Alive Tuning wrote:
Bigger discs give more surface area, for larger pads to bite onto. The larger the disc diameter, the greater the stopping power.
I use the Hi-Spec brakes using the standard (ancient) defender servo, and the pedal feel is superb. The choice of pad material makes a difference to pedal response too.
If we put bigger calipers and discs the feeling and the performances change completly in better, but if we put a 4 pot billet front calliper conversion (like the one you are preparing) and we do not change discs and pads, the friction surface remain the same. In that case the fading can occur in the same way.
Hi-spec pads reduce this symptom, also hi-spec discs, but the downside of this change is the price Matteo
Defender 110 Td4 SE MY 09
10th Mar 2011 9:56am |
TSAF
Good afternoon
a brake set (front & rear calipers / discs) from a destroyed 2008 RR S (Supercharged Jaguar AJ-V came up. I can get the kit really cheap. Would I be able to fit them on my 110 Puma.
4th Nov 2024 1:23pm |
