Home > General & Technical (L663) > Cant clear codes with Gap G3 |
DrRob Member Since: 29 Mar 2017 Location: Hampshire Posts: 169 |
You need a G4 IID for the new Defender I thought? MY25 90 D350 X-Dynamic HSE in Silicon Silver and coil sprung
1974 Series 3 Lightweight = "Millie" Many Range Rovers and Land Rovers over the years 😂 1949 80" - still in family since 1975 |
29th Oct 2024 5:09pm |
xexitenglishx Member Since: 17 Jul 2023 Location: NYC Posts: 2 |
I didnt think so just to reset codes. I have the g4 on order. Everything i activated seems to be selectable with the g3.
29th Oct 2024 5:23pm |
lightning Member Since: 23 Apr 2009 Location: High Peak, Derbyshire Posts: 2754 |
The tool stores your original settings so just reset the vehicle back to default settings.
Once you change something it sometimes needs to be driven in order to properly activate. l tried to set the more accurate speedometer and it threw up a "4wd not available drive with caution" error. l reset it but the error remained until l had driven a short distance and cycled the ignition and then it cleared. |
29th Oct 2024 6:43pm |
