![]() | Home > Puma (Tdci) > Britpart exhaut |
roche1800 Member Since: 07 Apr 2020 Location: derbyshire Posts: 350 ![]() |
Does anyone know who makes Britpart exhausts for TDCI please
I think the S is top of the range at £700.00 and not the normal exhausts …
Esben Kold Member Since: 14 Oct 2023 Location: Horsens Posts: 27 ![]() ![]() ![]() |
Ok, I only found that one when filtering for a 110 Puma. If the company, behind the cheap ones, is not explicitly advertised I would assume that britpart are not proud of it.
NickMc Member Since: 01 Oct 2014 Location: Norn Iron Posts: 1681 ![]() ![]() ![]() |
All the aftermarket ones are pretty crap and don’t last long now. Better trying to pick up a take of one off someone that’s fitted a upgrade.
Dinnu Member Since: 24 Dec 2019 Location: Lija Posts: 3487 ![]() ![]() ![]() |
I fitted an aftermarket straight through mid section, but in stainless steel.
The fit was horrible, I had to re cut the ends and re weld, and had to re do the hangers as they were completely wrong. They are advertised to have material as 409 stainless steel, not the most stain - less, and the flanges and hangers are still mild steel that will readily rust as the flanges on the genuine exhausts. In the end you get what you pay. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing 2012 90 CSW, 2.2TDCI, Santorini Black |
Will.I.AM Member Since: 16 May 2013 Location: Hertfordshire Posts: 425 ![]() ![]() ![]() |
After having various setups i have deciede to bite the bullet and go for a demand engineering exhaust - good guys to deal with and a seriously nice bit of kit, both easy to install and looks and sounds fantastic. Defender 130 HCPU TD5
diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6143 ![]() ![]() ![]() |
mini Anaconda Member Since: 23 Aug 2016 Location: Thames Valley Posts: 804 ![]() ![]() |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20645 ![]() ![]() |
I don’t know why but Britpart reminds me of:
