![]() | Home > Technical > Puma loom heated seats |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6657 ![]() ![]() ![]() |
Likely aftermarket heated seat loom has been added to your bulkhead loom - colours don't match factory.
One solution is change the connectors for factory type ones. ![]() ![]() |
shanecl Member Since: 20 Mar 2013 Location: Louth Posts: 522 ![]() ![]() ![]() |
it threw me off completely,
Thanks Martin, great so just a matter of changing plugs. have you got them on your site, I'll have a look |
I do have them, earliest I can post is Tuesday next week though
Thats no problemos
https://fnltd.co.uk/shop/defender-heated-s...-p125.html
perfect, thanks Martin, would you have the male plugs also
Listed for the Webasto pump, but yes here:
Connector kit: https://fnltd.co.uk/shop/fbh-fuel-pump-con...-p106.html With wire: https://fnltd.co.uk/shop/fbh-fuel-pump-con...2-p73.html ![]() ![]() |
Thanks Martin, order went through
Thanks!
