Home > Faults & Fixes (L663) > Advice Needed:Repairing Dent in MY24 Wheel Arch |
jim4244 Member Since: 13 Apr 2014 Location: Bedfordshire Posts: 808 |
Hi
I think that a dent repair specialist would be your best port of call. That looks as if it will push out without damaging the paint? Jim |
22nd Oct 2024 3:36pm |
WRFrance Member Since: 14 Nov 2015 Location: Deep in the West Posts: 16 |
Hi,
I would say a puller won’t work as well as the dent is too sharp and cannot be pulled out all the way without pulling/deforming the surrounding material outward too far. This needs to be massaged out from behind with a block held against from the outside. I think this can we done without the need to paint from the outside. Make sure they don’t damage the paint on the inside of the wheel arch to avoid corrosion at a later point in time. Respect to your garbage guys for their honesty! |
22nd Oct 2024 5:17pm |
lightning Member Since: 23 Apr 2009 Location: High Peak, Derbyshire Posts: 2865 |
Best to spray wax on the back of the panel after the repair just in case. Get a can of aerosol wax rustproofer and give it to the dent removal person. |
22nd Oct 2024 6:47pm |
Ianh Member Since: 17 Sep 2018 Location: Essex Posts: 2048 |
If you are going to spray wax, use bilt hamber dynax UB
22nd Oct 2024 8:23pm |
revd Member Since: 20 Apr 2024 Location: England Posts: 137 |
Funny how classic Defenders are similarly pockmarked and mostly left un-repaired
22nd Oct 2024 9:04pm |
Grouse Member Since: 16 Apr 2012 Location: on the hill Posts: 521 |
PDR will get rid of that no problem - I’ve had far far worse successfully removed than that. It needs massaging out from behind - more than likely glue will distort that and you will end up spraying it - which can be detected as spraying changes panel reflections and also you can see excessive paint depth
22nd Oct 2024 9:30pm |
ruben Member Since: 04 Feb 2021 Location: ASTURIAS Posts: 207 |
I’ve see a total write-off for less!!🫢 Defender 110 SE I6 D250 23MY
ExDiscovery 3 TDV6 SE |
22nd Oct 2024 9:31pm |
LR Nuts Member Since: 10 Aug 2022 Location: UK Posts: 1155 |
It may be cheaper to replace all 6 plastic wheel arch trims, for the ones that fit further up the outer arch.
(Black on Black isn't the best photo) |
23rd Oct 2024 9:23am |
That seems like a great idea!!
I did one similar thing! this Click image to enlarge motivated this! Click image to enlarge These are the drawbacks of having elephant ears!! I suppose!! 😉 Defender 110 SE I6 D250 23MY ExDiscovery 3 TDV6 SE |
23rd Oct 2024 9:59am |
F-Typical Member Since: 05 Sep 2024 Location: Hereford Posts: 43 |
Unless you're either a PDR tech or work in a bodyshop that uses PDR techniques, probably best to just take before and after pictures to confirm you're happy with the result? |
27th Oct 2024 5:47pm |
