![]() | Home > Puma (Tdci) > Wipers blowing fuses |
NickMc Member Since: 01 Oct 2014 Location: Norn Iron Posts: 1681 ![]() ![]() ![]() |
Have a look at the wiper boxes incase they’re seizing up.
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20645 ![]() ![]() |
Wiper boxes and rack most likely seized, could be putting high load on the motor drawing excessive current.
Lube the wheel boxes with a light penetrating oil like WD40 as a temporary fix, let it bass off too just in case there is any sparks near the motor you never know. You’ll likely need a new rack and wheel boxes plus park switch, if unlucky a new motor but that might not be the case if it runs okay without load. TheThunder Rolls🇬🇧🇺🇸 ⛽️🛢️⚙️🧰💪 |
Don’t loose the short tube end of the rack when you take it apart 👍🏻
jim4244 Member Since: 13 Apr 2014 Location: Bedfordshire Posts: 856 ![]() ![]() ![]() |
Morning
Same symptoms as my wipers just before the drivers side wiper gearbox seized up. Unfortunately you will have to bite the bullet, remove the dash and replace the gearboxes. Not as bad as it first sounds and should be completed in 1.5 - 2 hours. Jim |
revd Member Since: 20 Apr 2024 Location: England Posts: 201 ![]() ![]() |
If it’s just the spindle through the bulkhead peel back the outer seal and squirt motorcycle chain spray and some wiggling back and forth
Mike2a Member Since: 20 May 2024 Location: Devon Posts: 8 ![]() ![]() ![]() |
Thanks for the reply, how did you get the wipers to stop? The only way I can do this atm is to pull the main fuse.
Just my thoughts but it sounds as if the wiper switch has been damaged, probably by inserting the higher rated fuse after the lower rated ones kept blowing.
When my wipers started to blow the fuse I too put a higher rated one in. In the end it damaged the wiper motor and I had to replace the entire wiper array. Check the wiper switch as it may have welded itself to permanently on. Jim |
Thanks for the context it makes sense. I'll start pulling it apart tonight.
Regards mike |
macfrank Member Since: 05 Nov 2015 Location: somewhere in the north Posts: 1105 ![]() ![]() ![]() |
uff. Sorry, but that wasn‘t just a bad idea but actually dangerous. Fuses usually blow for a reason. It‘s never clever to just replace them and never with a higher rated one. And 10A more is a lot! Fuses are there to protect the wires from going up in flames in case of a short. If the wire survives, the next weaker element in the circuit may suffer, adding another problem. |
discomog Member Since: 09 May 2015 Location: Notts/Lincs Border Posts: 2535 ![]() ![]() ![]() |
Frank makes a very valid point which many people fail to recognise and that is the fuse is there to protect the wiring and prevent breakdown of the insulation and possible fire. The fuse is not used to protect things like wiper motors, heater motors etc - just the circuit. Defender 90XS SW
Well it was just the relay in the end.
And I'm well aware of how and what a fuse is use for thanks. |
That’s good news.
