200Tdi Crank End Float
Need Advice.
Before removing the crankshaft, I measured .004 of end float. Specs I got out of the FSM says I should have from .002 to .006, so .004 is right in the middle, perfect.
Installed new standard .025 thrust washers from Turner with the OEM spec crank and now I see no float at all. The crank rotates smoothly with the main caps torqued to 98 lb ft.
Do I go back to the old thrust washers or will the new one's "lap" in during break-in?
These are the washers that came out of the engine.
22nd Oct 2024 4:33am
Dinnu
What do you mean by "standard .025"
It is either standard or oversize I think? Although 0.025 is quite big, unless they are 0.0025 oversized.
When I was rebuilding my 19J, I tested 0.0025 oversized, and same result, no endfloat. So I installed the standard ones. My originals where also in very good condition with 128k odd miles and a lot of clutch use.1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot vote in polls in this forum
