![]() | Home > General & Technical (L663) > Heads up display information displayed. |
Mrburt Member Since: 04 Jan 2023 Location: Shropshire Posts: 39 ![]() ![]() |
If the settings in Terrain Response are, mud/ruts, rock crawl, sand or configurable then the HUD will display the wheel positions and pitch and lean angles relevant to off roading situations.
The only settings that will give just the normal road biased info such as nav, sign recognition etc is comfort and grass/gravel/snow, settings consistent with potential normal road use. Hope this makes sense. |
David007 Member Since: 26 Oct 2022 Location: Angus Posts: 111 ![]() ![]() |
That’s brilliant, thanks. I just need to give it a go when I’m next home.
