Home > Puma (Tdci) > Puma MT82 stuck in first gear |
mattsccm Member Since: 11 Jul 2022 Location: Glos Posts: 7 |
Click image to enlarge Hi. I found this great place whilst trying to find the solution to a problem with my 57 plate Puma 90. It is stuck in 1st gear. My fault, I leant against the lever and in effect tried to knock it from 1st to neutral. Cut a long story short I found this thread https://www.defender2.net/forum/topic17158.html Looks worth a try but I can't easily get that far as my LR experience is no more modern that my 300tdi vehicles . I am trying to lift the top cover off but am a touch worried that I might screw things up. I have already, unintentionaly lifted the gear lever out and because, I guess, it was jamned in 1st it seems reluctant to go back. I bet it will later though. In my pic I have the red bolts loose. The black one on the right is being a sod. Tight and limited spanner space. When I do get it off can I just lift the cover or will the hi/lo lever and linkage get in the way? Also I am not going to get something spring off and never go back am I? Once I get these bolts off what happens next? Is it a case of following the other thread to at least see whats the problem? Many thanks all. Any help much appreciated. Matt |
11th Jul 2022 6:05pm |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17457 |
You're doing fine so far. You need to get the last bolt out, then lift the lever pedestal base thingy out of the way. Nothing will spring out. The instructions you need to follow are these from the linked thread:
The high/low linkage can stay connected, since it is possible to move the assembly out of the way without disconnecting it (disconnecting it is fiddly on the MT82). The photos in jst's post on the last page of the linked thread are useful, they make it clear which detent you need to remove.
This thread https://www.defender2.net/forum/topic60607.html is well illustrated and may help as well. Alternatively typing "detent" into the search page and searching for thread titles will produce about two pages of results of varying usefulness. |
11th Jul 2022 6:57pm |
Cheers. I'll have a go in the morning. Spanners now away and I'm off to tackle the Royal Enfield instead.
11th Jul 2022 7:23pm |
Too true. How I miss my previous 110. D plate. Started as a 2.6 petrol CSW. I stuck a 2.8 Isuzu in it. Brilliant. Carried everything from firewood to dead boar. People to bikes. Flooring was a thick layer of underseal and some rubber mats and it was a nicer ride as well.
Off to have another go . |
12th Jul 2022 6:03am |
Thanks for the link.
Now puzzling on where the 4th bolt is as in that post. I have 3 out and the alloy cover moves a touch. Do I really need to disconnect the hi/lo difflock lever? Trying to keep things simple as everything that comes off is potential to be a problem getting back on. Cheers. |
12th Jul 2022 6:48am |
My recollection is that you don't need to disconnect the H/L lever, but my recollection may be wrong. I thought you could shift the assembly to the offside enough with it still connected.
In my defence it is several years since I last did this on the car. |
12th Jul 2022 2:01pm |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20461 |
^^^^ This sounds correct to me when I had it off a few years ago.
Though I took it all off as it was an ideal time to lube the linkages and also fit the spacers to that part. Rounded off with fitting a Shift R to finish off the job in one go. There is torque specifications for the fixings for when refitting and tightening in the Worskshop Manual. Pays to lube the gear shifter assembly and ball joint and hi low mech etc in the process also. On mine I found that the assembly had cracked and broken, so as I had to replace it I went for the Shift R anyway and not Genuine. It’s the Nylon that’s goes on the shifter assembly. There are other threads on here regards the spacers and part number. It’s possible that this maybe an issue causing you to find it difficult to get in and out of gear, it’ll definitely cause excess movement in the gearstick. No Guts, No Glory. 🇬🇧🏴🏴🏴🇮🇪🇺🇸⛽️🛢️⚙️🧰💪 |
12th Jul 2022 2:42pm |
Steve A Member Since: 17 Jul 2021 Location: Tyne and wear Posts: 1 |
Had to do this myself couple of months ago and if I remember rightly the 4th bolt is under the hi lo shifter. Didn’t have to disconnect it though.
12th Jul 2022 3:10pm |
Still stuck. Can't find any 4th bolt. The top cover moves a bit, rather too much for it to be bolted down but not enough to move. I did take the 4 bolts that hold the diff lock lever in place out but that just allows it to lift enough to disengae from the lock rod but not lift out. Not solved anything.
Don't want to lever away at the cover, that is the bit held down by the 2 red and one black bolts in my pic, in case I wreck something. Is there definitely a 4th bolt or hwo do I move things? Help! FOUND the bolt. Have to disconect the hi/lo connection and the lever lifts out.There it is |
12th Jul 2022 4:56pm |
Getting there thanks to you lot. Found the missing bolt.Took the linkage to the hi/lo off.Lever off. Casing off. Bit of a pain taping the detent out but it came. One flick inside and the front wheel spins. Levers back on and all moves
Time to watch the Tour de France and then I'll give it a run. Fingers crossed everyone! |
12th Jul 2022 6:08pm |
Well done!
12th Jul 2022 6:43pm |
LR90XS2011 Member Since: 05 Apr 2011 Location: bickenhill Posts: 3645 |
love this forum DEFENDER 90 TDCI XS,
12th Jul 2022 6:57pm |
Well it works. Just a short spin up the road so that I could roll home if it packed up. Seems OK.
Only thing to look at is the diff lock linkage which may well have been stiff anyway. Had to disconnect the ball joint to lift the lever out. Thats back on but the whole thing won't go into low ratio. haven't looked yet. Any tips with that? My old 110 was used off road much more and spent much of its life as a tractor so more hi/lo swapping. Many thanks people, much appreciated. |
12th Jul 2022 7:58pm |
Kev the Rev Member Since: 04 Jun 2023 Location: Ripon Posts: 39 |
Got stuck in reverse so I have ordered a new detent spring from Ashcrofts so just prepping this weekend
I'm at the same stage as the first photo in the thread I have removed the gear lever and removed the 4 bolts for the high/low lever but can't lift the lever out. One person said that you don't need to remove the linkage but I think I may have to. The top linkage with the square white block just slides out to come off but how do I remove the bottom linkage? Does it just "ping" off As usual, any help would be appreciated and if anyone has a link to any videos that would help |
19th Oct 2024 2:29pm |
