![]() | Home > General & Technical (L663) > Has anyone added Ambient lighting to a L663? |
Gareth Member Since: 12 Dec 2011 Location: Woodford Posts: 1126 ![]() ![]() |
Unfortunately due to covid parts supply issues, my 2021 Defender X Dynamic HSE could not have ambient lighting fitted when I bought it new. It would have delayed the order so chose to delete them.
Is it possible to add them aftermarket? 2021 Defender 110 X-Dynamic HSE D300 MHEV 1966 S2a 109 aka Betsy |
DaveCNB Member Since: 15 Mar 2022 Location: So. Cal Posts: 64 ![]() ![]() |
The videos I've seen about retrofitting the ambient lighting all seem like it's a pretty involved process (have to take apart many interior body panels and the dash....) and you need a GAP tool to activate the function for your PIVI Pro to control the custom colors.
As a way easier/cheaper alternative, I got these foot well light modules from Powerful UK which you can change set the color to white, blue or red. They dim properly and are brighter than the stock/OEM light modules: https://www.powerfuluk.com/collections/new...r-l663-2pc They're really nice and just £17.50 GBP for a pair (one each for the front left and right foot wells) and only take a couple of minutes to install -- super easy. It's not as comprehensive as the fully adjustable ambient lighting option, but if you are fine with blue or red, it's a 80% solution for much less money.... The lighting at the door handles and the door pockets remain white, but it's pretty easy to apply blue/red translucent color tape over the installed stock lighting strips to get all the lights to match. Yeah, low tech, but most folks will probably not notice the difference and alot easier/cheaper/riskier than taking apart your dash and door trim panels. -------------------------------- "Chonky" 2024 Defender 110 X-Dynamic SE P400, Pangea Green, Air Suspension, Off Road Pack, Urban Pack (exposed recovery points), Factory Side Steps |
alamri666 Member Since: 24 Dec 2023 Location: Abu Dhabi Posts: 6 ![]() ![]() |
I did it , I bought from aliexpress and I instal by my self, then I change the ccf option to enable it. |
Mark1107 Member Since: 19 Oct 2020 Location: Los Angeles Posts: 75 ![]() ![]() |
Link to where you bought it?
Re: Has anyone added Ambient lighting to a L663? Report post Gareth wrote: Unfortunately due to covid parts supply issues, my 2021 Defender X Dynamic HSE could not have ambient lighting fitted when I bought it new. It would have delayed the order so chose to delete them. Is it possible to add them aftermarket? I did it , I bought from aliexpress and I instal by my self, then I change the ccf option to enable it. 2022 Defender Trek Competition 110 collectors edition! 2020 Defender 110 P400 Full Explorer Pack 7 Seater HSE Fuji White(sold) 2020 SVO Range Rover L405 Full Size Spectral Blue Chromaflair 2014 Range Rover L405 Autobiography Full Size Aintree Green 2014 Dodge Viper GTS Stryker Green |
rakusak Member Since: 02 Apr 2025 Location: Austin Posts: 3 ![]() ![]() |
Any one do retrofits on models that had the local wiring provided?
