Home > Puma (Tdci) > My VCV Journey
Page 5 of 5 <12345
Joyosa
France 2002 Defender 110 Td5 SW Coniston Green
Thanks I will give that a try - did it once before and it showed a knackered injector.
Post #1048515 13th Oct 2024 9:56am
MK
After 3000 km
Evident signs of wear just after 3000 km and filter change. Using a 20x handlens I culd not see deep scratches but only wear. Also looks like this little piston is not totally cylindrical due to either design or poor machining. This one supposed to be an original part, but who knows since most Denso parts nowadays are counterfit.
 Puma 110" SW
Post #1048521 13th Oct 2024 12:41pm
andy63
Is the vcv valve on the 2.4 dismantable..
I've seen vids where a small clip in the base allows removal of the valve plunger this but on the one on my 2.2 I'm pretty sure it's a sealed unit..
I think I'd have to destroy it to get at the plunger
Post #1048539 13th Oct 2024 4:09pm
MK
Indeed it is. A bush mechanic would polish it with 1000-2000 grit or turn the plunger inside. Puma 110" SW
Post #1048542 13th Oct 2024 4:15pm
Page 5 of 5 <12345
