Home > Technical > Removing seat box fuse wires (TD5) |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6633 |
Remove the bolts/screws from the top. Those wires have terminals (right angle shaped I think) which are screwed down.
Pop the top off and you’ll see 1988 90 Td5 NAS soft top 2015 D90 XS SW |
10th Oct 2024 7:45am |
Tandy Member Since: 14 May 2024 Location: WA State Posts: 18 |
Thanks Martin, worked like a charm.
Actually I think the plastic top just popped off with a screwdriver and the only screws I had to undo were the two ground/earth brown wires. I removed all the screws initially and it turned out that wasn't necessary. Those were the fuses., but now I know how easy it is to change a blown fuse. For anyone else it may help, after the ground wires are disconnected from the fuse box, squish the rubber grommets down and push them through the seat box hole. Slowly pull through all the wire harness. There's also one clip on the underside of the seat box that needs to be pulled up by hand. Cheers Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge Last edited by Tandy on 11th Oct 2024 5:24pm. Edited 1 time in total |
10th Oct 2024 5:03pm |
Linds Hanson Member Since: 16 Jan 2021 Location: Cornwall Posts: 489 |
Be careful those thick brown wires are live + feeds to the fuse box.
11th Oct 2024 3:52pm |
Correct - NOT ground wires!! 1988 90 Td5 NAS soft top
2015 D90 XS SW |
11th Oct 2024 4:51pm |
Thank you for the clarification.
The battery was removed a few days prior. |
11th Oct 2024 5:22pm |
NickMc Member Since: 01 Oct 2014 Location: Norn Iron Posts: 1654 |
Yes live feed from battery positive. Be careful tightening them back up as it’s easy to strip the nut/damage the housing. Just little more than hand tight
11th Oct 2024 7:11pm |
