Home > Td5 > Have you heard this sound from the engine?
The wildest man in town
Sweden 1999 Defender 110 Td5 PU Coniston Green
Hi everyone,
After two months of standing still, my td5 just suddenly started to make this noise just before it cuts off.
I know it’s lot a lot to go from, but anyone having a clue?
If I ignite again it will do the same process again, run a little bit and then make the noise.
Here’s a video of the sound https://youtube.com/shorts/FiDk_vPUDOw?si=D-zLkBOLtC2puHJf
Post #1047860 6th Oct 2024 10:44am
andylee
Sounds to me like the starter is re engaging… but hard to tell from the clip.
Hope you get it sorted,
Post #1047879 6th Oct 2024 1:18pm
landy andy
Check the harmonic balancer / bottom pulley and see if it’s failing.
Post #1047891 6th Oct 2024 3:42pm
Thank you very much for the response! Haven't found the issue yet and will have it towed to my repair guy for further investigation.
Post #1048171 9th Oct 2024 7:46pm
My repairman was busy till end of November, so here I am again 😅
Removed the alternator belt and ignited/ran just fine. So the issue is somewhat connected there.
All the things the belt touches seems fine by hand touch. Any ideas of further trouble shooting, or should I replace things one by one starting with the harmonic balancer?
Thank you 😘
Last edited by The wildest man in town on 16th Oct 2024 6:04am. Edited 1 time in total
Post #1048814 16th Oct 2024 5:38am
jim4244
England 2007 Defender 90 Puma 2.4 CSW Zermatt Silver
The belt tensioner can cause a lot of noise when it begins to wear out and fail. I would start with that.
Jim
Post #1048816 16th Oct 2024 5:53am
Thanks Jim!
I'll try replacing the tensioner for sure!
Edit
So I'm thinking it's either the tensioner, harmonic balancer or the PAS pump.
But not really sure there's an issue with the harmonic balancer since it doesn't make the sound without the belt but still moves during idling?
Any ideas? 🤗
Post #1048817 16th Oct 2024 6:23am
Ok,
Replaced the Harmonic balanser and the belt tensioner without success.
Any other ideas? Could it some how be the generator?
Grateful for any ideas.
Post #1051204 10th Nov 2024 6:48am
rustandoil
That's quite a noise!.... You could well see where that's coming from if you get someone to switch off while you're looking under the bonnet?
Good luck!
Post #1051206 10th Nov 2024 7:16am
Can’t locate the sound even inside the engine bay. The issue occurs when the belt is mounted. Just replaced the tensioner and harmonic balancer but the noice is still present.
Did have an issue with the generator couple of years back but replaced it. Might it be something wrong somewhere that consumes the generator?
Post #1051248 10th Nov 2024 3:54pm
It's going to the repair shop early December Very Happy
Tried to turn the steering wheel while cranking the engine to check if the axel in the steering servo was broken. But it doesn't feel like it.
My money is on the generator some how.
Could it be that the generator is doing its thing for a couple of seconds, then overloads the system in a mysterious way?
The plot thickens 😅
Post #1051295 11th Nov 2024 6:59am
