![]() | Home > General & Technical (L663) > Side mounted gear carrier L663 ..... mounted left side!? |
J77 Member Since: 04 Nov 2019 Location: Fife Posts: 3460 ![]() ![]() |
Check powerful uk out on YouTube
DFNDER Member Since: 02 Oct 2023 Location: Perth WA Posts: 140 ![]() ![]() |
Pretty sure there's not enough sheet metal or reinforced material there to mount the box on the other side. POWERFUL UK does the adapter plates so you can fit the box on polisher side, but then that's using the ladder mounts AFAIK. What about fitting the Awning on the rhs, then you can have the ladder on the correct side and still access the roof with the awning open?
LR Nuts Member Since: 10 Aug 2022 Location: UK Posts: 1261 ![]() ![]() |
This is the Powerful MOLLE plate bolted to the LR nutserts, then the ladder attached to that plate.
![]() Click image to enlarge Then the Side-Carrier mounted on a MOLLE plate on the other side. ![]() Click image to enlarge |
